Mike104
    13
Everything posted by Mike104
  1. Take out the screw in the handle (under the plastic cover) pry off at the bottom (towards you) Then lift up once the door panel is free from the door
  2. The 99's Legacy and Outbacks seemed to have this issue. May want to read the link I posted for a fix.
  3. If you are looking to cut costs why not just replace the system with a kit from Rock Auto Everything but the cat $186 + Shipping http://www.rockauto.com/en/moreinfo.php?pk=5943225&cc=1317333&jsn=353 Originally your car came with a two piece cat Front CARB compliant: $220 http://www.rockauto.com/en/moreinfo.php?pk=6594836&cc=1317333&jsn=364 Rear CARB compliant: $211 http://www.rockauto.com/en/moreinfo.php?pk=6595176&cc=1317333&jsn=362 I don't know if the one-piece will fit $235 http://www.rockauto.com/en/moreinfo.php?pk=4306395&cc=1359390&jsn=401
  4. Walker gasket for front side of Cat is 31388 Port Size is 2" bolt hole center to center is 3.340" http://www.walkerexhaust.com/catalog/walker-exhaust-systems/e-catalog-lookup/31388 Walker Donut for aft side of Cat is 31614 Inside is 1.9" and OD is 2.6" http://www.walkerexhaust.com/catalog/walker-exhaust-systems/e-catalog-lookup/31614 Click on Tech Specs Tab when at link to verify sizes
  5. Blinking check engine light is Misfire. Knock Sensor is on the block underneath the intake manifold on the rear of the engine https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&cad=rja&uact=8&ved=0ahUKEwiB05Ok67vWAhWmxYMKHcDfClgQtwIIPjAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DJBX7ctGGgDo&usg=AFQjCNFm8vehiUonFRGuU9cNMxgPINuWPA Google is your friend $7 shipped on ebay http://www.ebay.com/itm/Knock-Sensor-FOR-SUBARU-FORESTER-IMPREZA-LEGAZY-OUTBACK-22060-AA061-/222478168616?fits=Make%3ASubaru&hash=item33ccbb7228:g:y7cAAOSwzqFY9HN1&vxp=mtr
  6. http://www.ebay.com/itm/TEMPERATURE-CONTROL-W-AC-LHD-FITS-95-97-LEGACY-73662/172389367174?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D47507%26meid%3Da2ffd54f14294f7da6d9019d0bcf9b25%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D122714936091&_trksid=p2047675.c100005.m1851 Or check your local pull and pay yard. Also check www.car-part.com and search near you
  7. Take it to another dealer and ask for an oil consumption test. If it burns more than 1/3 qt or 10.7 oz quart in 1200 miles they will put in a new short block under warranty. This is a well known issue and Subaru issued an extended warranty for the FB engine. Oops, it did not apply to 2015 Outbacks https://www.girardgibbs.com/subaru-oil-consumption-class-action-lawsuit/ https://www.cars.com/articles/2011-15-subaru-oil-consumption-update-1420683845519/ May want to check if it has any oil leaks. How often do you change your oil and what oil do you use?
  8. Starter is a definite possibility since it dims (meaning the starter is being energized but not rotating. Remove the starter and take it to a chain auto parts store and they can test it for free. Much better option than an ECU.
  9. Clear the codes and see which ones come back first. The misfires and knock sensor codes could be causing your issues. Manual or Auto? I had the P1507 and it was related to the Neutral switch (MT).
  10. What car do you have? 1999 Outbacks had a known bad solder joint in the speedometer. http://www.ultimatesubaru.org/forum/topic/112272-99-speedo-fix/
  11. Where did you buy your struts from? KYBs (OEM supplier) are like $60 each from Rock Auto. Yes they are more expensive than $15 shock absorbers.
  12. car-part.com lists six in Colorado that are green. Try calling the parts yard and get them to send you some pics
  13. And to verify go to www.car-part.com and it will tell you confirm the years. I don't doubt the post above
  14. I put a JDM EJ201 into my '03 Forester and swapped the Camshaft/Crankshaft gears and applicable sensors over. Started right away and runs like a champ. Used my original Intake Manifold/wiring harness.
  15. I usually turn my key to ON and wait until the fuel pump shuts off before I start my car. Works everytime.
  16. Try calling the Service Department and ask to speak to one of their techs. They may be able to give you an idea if that is correct.
  17. That's a fair way to offer a reasonable price. Way more that you would get from a dealer on a trade in (maybe $500)
