Everything posted by emarsh
Overheating and no heat issues... please help!
my other question that i completely forgot to ask... is there an actual bleeder anywhere in the system?! i have tried the bleeder on the side of the radiator and a tiny bit of steam came out and then itightened it up once some coolant came out... i am soo stumped on this situation!
here is a picture of the used radiator... seems to have a few small leaks that i wouldn't think are causing my issues... but i am gonna call the junkyard i got it from to get it replaced hopefully... does anyone think that this could be contributing to the problem? thanks
bump... if someone tells me what is causing the problem i will give you $20!! that's how desperate i am!! i just can't figure out what the problem is!!!!!
well i'm pretty sure that it is something related with circulation... i just ordered a new (used) water pump under warranty to try that... the water pump will be here tomorrow so i open to any and all suggestions in the mean time and anytime really... i am also going to do a heavy flush of the radiator... i'm pretty sure it realted to the circulation since it only overheats when driving it and not sitting at idle... let me know what anyone may think! thanks again for the help so far... -Sam
i agree... and i don't mean to sound cocky in anyway at all when i say this, but i know for a fact everything i did was done right! lol i'm just stumped as to what could have randomly caused it to happen... that's why i wasn't sure if it was due to getting hot a couple times... or maybe if somehow the radiaor is bad even though coolant went in the top and came straight out of the bottom... or maybe for some odd reason the new water pump is a defect, even though is felt and looked and seemed perfectly normal... and i've never seen a car run hot due to the heater core being clogged either... and it really seems like the radiator is flowing fine since it felt hot even after driving on the freeway in 15* weather... if it wasn't flowing i would definitely assume it would be cold... but is it safe to say that the motor is ok...? that is my biggest fear as i really don't feel like rebuilding this one right now as i need the car... any other ideas from anyone about anything about something about this problem that could be causing it?! i'm so stumped right now... thanks grossgary for all the input! i appreciate it!
ok... the thermostat is a cheap parts store on, but it is opening... the upper hose stays cold until it opens then does get hot.. the upper and lower radiator hoses both get hot once at operating temperature... one of the heater core hoses gets hot, which i'm assuming is the inlet, the other one does not... however i don't think this will cause the car to overheat, just me though, i may be wrong... as for the radiator... after the car has been running, the driver side is cold due to the fan constantly pulling air through, i can feel it sucking air... and the the passenger side is hot to the touch... i can feel this since i took to condensor out when i replace all the parts... i currently do not have a radar gun for the temp but i can feel the heat from the 3 out of 4 hoses... i'm thinking about bypassing the heater core for now to test the problem... but how likely is it that the car will overheat due to the heater core, i've seen many cars with clogged heater cores that still run perfectly fine... :/
it is a new water pump... i also forgot to add in the OP that when the old water pump broke and the bearings went bad, the fin scored the block just a tiny tiny bit... but i am 99.9% confindent that it isn't enough to cause this issue... you could barely feel it, all it really did was polish a little part, not even any metal shaving from it... just throwing anything and everything i can out there to help diagnos it... thanks EDIT: i'm assuming it's a rebuilt one from the parts store, it was $40 with a lifetime warranty... it does say subaru on it though if that matters... sorry for the mix up
ok, i am new to subaru's so i was not sure if that related to all of them or not... thanks for clearing that up! and also, there is no type of smoke at all so it doesn't seem like coolant is leaking into the cylinders... this car ran perfect and i put 5000 miles on in 2 months when i got it in October! i don't know what would just cause it to give me so many damn problems! ahhhh
the cylinders appear to be clean and dry from what i can see... and the spark plugs came out completely dry and smelled 100% normal... i did however find out that on of the spark plug holes seems to be stripped out when i tried to tighten one... but i'm not worried about this having any realtion to the issues i'm having...
correct about the common signs... my only concern is that i have read that sometimes these head gaskets blow in a way that just leaks exhaust gases into the coolant... so my fear is maybe that is why it is getting hot...? and it never fully reached the H and it was only ran close to H for a total of maybe 1 minute combined with the few times it climbed... and i am hoping the motor is still good, too... i'm planning on taking it to a buddy's shop for a proper flush soon... any other suggestions or advice would still be greatly appreciated! thanks
also, this problem developed after about a day of driving after fixing it all... suring that first day, it seemed to run perfectly fine... just trying to give all the details i can to help make the diagnosis easier...
the old one is pretty bad... the fan put a hole almost all the way through it, i doubt there is any saving it... thanks
the used raditor seemed to flow fine when i got before i put it in... i simply tested it by pouring some coolant in and it easily all came out the other end... i'm trying to avoid any water at this point because the temperature has been in the teens and i just don't want any of it to freeze... i also forgot to mention that i had the front end jacked up as far as i could get it while doing the burping and trying to add more coolant... i've squeezed every hose on the car with no success... am i wrong to possibly think the compression numbers are too high due to coolant possibly leaking into the cylinders...? just a thought as i'm not quite sure what the compression is on these motors to know what it should test at... thanks for the advice! any is appreciated!
let me start by saying that i've done a lot of searching... and i can't find anything that relates exactly to mine... i have a 1992 Loyale 4WD with 195xxx on it, timing belts where replaced by the previous owner at about 180xxx, they are infact new as i have seen them and are gatorback belts... here's the issue, and i apologize if this is too long... it starts with my friends trying to launch my car is snow when i told him not to... the motor mounts are weak, so the fan smacked the radiator and put a hole in it... we limped it home and it almost reached the red on the gauge but never got into it... i put a new radiator in hoping the fan wouldn't need to be replaced since a blade broke off... after 40 miles the fan ate the water pump bearings up and came apart and smacked the new radiator... i got a new water pump, a used radiator, and a used fan... it's all together and has been for a few days... the problem now is the car will start heating up and after 15 or 20 minutes of driving will almost get to the red, even though i haven;t let it fully reach it... if i park the car for maybe even 5 minutes and start again, it starts down at the normal area for a few minutes before climpbing again... this happens city or highway driving... also, if the car idles, it will not overheat no matter how long i run it, it just runs slightly warm... but still just less than 1/2 up the gauge... the other problem i that developed at the same time is no heat... if i turn the heater off for about a minute, then turn it on, it will blow hot for about 5 senonds then turn cold... the flap and blower motor are working fine... the first thing that came to mind was a clogged heater core even though i don't know what would have randomly caused it, and i don't know why that would cause the engine to get hot... i have tried to burp the system many times with no success... however one hose running to to heater core is hot while running and the other one stays cold and doesn't feel to have much pressure... i pulled the return hose off while the car was running and it did run out... it didn't have much force to it but it came out at about the rate of pouring a bottle of soda... i also can't get the car to take anymore coolant... i have let it idle for an hour or so while trying to burp the system... also, i replaced the thermostat with a cheaper parts store one about a month ago... and it is opening and working... and just in case it helps, the car has got almost to the red on the gauge a total of probably 4-5 times, i know i should never let this happen but i had to get off the road each time i let it get that high... i ran the car for about 20 minutes today and no success with burping it... i did compression test it afterwards though to determine the HG's.. the conditions were just about fully warmed up then shut the car off... pulled to fuse for the fuel pump... then wide open throttle for each with consistent number of cranks for each cylinder... the results DRIVER SIDE FRONT 203 REAR 192 PASSENGER SIDE FRONT 160 REAR 184 any help on this would be greatly appreciated... also, if it helps, i am a mechanic with full tools so don't be afraid to tell me to try something "harder"... i am currently reversing to hoses on the heater core to try and "free up" anything that may be stuck in there then putting them back to the original way... thank you -Sam
