3
Everything posted by tizzle
EJ20 AIR-WATER INTERCOOLER . I kinda want to get it, but then I'd have to worry about a better radiator probably, and a pump, and then figuring out plumbing, and the fact that I'm not going to have any money in a couple weeks anyways after I pump it all into my legacy. sidenote: found a good writeup about a guy installing one of these on his impreza HERE
I like getting, "A RX, I've never heard of that" from the parts guy
New engine in the RX: 2 problems
tizzle replied to tizzle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did change the oil, and put in 1 qt of marvel mystery oil, since there was only a few drops in the engine. I also got a brand new oil pump with the engine -
Just get the Tornado
whats the honeycomb project?
hmm, the oil level was nearly full when I 1st started it, then I topped it off after running a little while. Further suggestions? As far as the clutch, should I just mess with the cable adjustment some more? -
Finally started it up 2 nights ago, just put in a jdm engine, used my old intake manifold and accessories. Some of the EGR and cruise control lines were not matching up, after looking through all my manuals and even going through year specific manuals at the dealership, I said screw it, and plugged the hole. SO I started the car up, and its got a horrendous tapping noise. I'm guessing maybee the valves need to be adjusted??? I messed with the timing, and this changed nothing. Then I decide to drive it down the road and back. I pull half way out the garage to discover my brothers broken down truck behind me does not leave enough room to back out. So I try to go into 1st and the car doesn't want to shift, and then it does, but doesn't want to go both my subarus aren't running and now its snowing
Suberdaqve. I just swaped an engine from an jdm auto into my 5 speed , and the distributor was different. It had a bunch of extra wires coming off it. So I just used my old distributor
Oil pan gasket
head easy to warp when undoing them
tizzle replied to BobBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do you need the tigtening sequence? -
Check these guys from Lynwood out. http://www.foreignenginesinc.com/door/ Just purchased a jdm ea82-t from them recently. Delivered to my door next business day at no charge. Good prices!
Interesting things i found tonight
tizzle replied to Do It Sidewayz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ya, lots of people on Nasioc go from the series fuel delivery to parallel delivery. edit:found some cool pictures, but they disapeared -
I'm sorry but I haven't read into this swap much, but could this be done entirely with impreza parts, no xt6?
As his avatar says, Please disregard, he's probably drunk. GC8 is an impreza code, legacy is BH/BG/BD etc
sort of old thread, but it applies to me. so, If I were to just block this portion of vacuum hosing off, would it cause any ill effects? not one, but 2 actually there's 3 the epoxy idea sounds pretty good though. NO way in hell am I paying $89
Head crack (small enough to ignore?)
tizzle replied to Tycho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks a lot better than mine -
Air to Water or Air to Air Intercooler
tizzle replied to Myxalplyx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Kevin, don't you have a air water intercooler sitting around? -
Where can I get a bigger/better radiator??
tizzle replied to pwoens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bump, anymore info on adapting a legacy radiator, archemitis?
