Will Smith
Everything posted by Will Smith
This Brat runs and drives well. 5 speed transmission w/new clutch disc and pressure plate assembly. Extended drive shaft w/replaceable u-joints. Replaced front and rear seals on the engine, heater hoses and bypass hoses. Passed Clifornia smog about 500 miles ago. Will smog again if buyer is to register in Cali. 132K miles. Looks like near new brakes, excellent tires, new upholstery including new foam in the seats, carpet and padding on the floor. The dash has one large crack, now has a rug on it. The paint is a really nice orange color(paint code #547), no wrecks I can see. Has parking lot dents. Rust in the bed on the drivers wheel tub and under the battery tray, both areas are repairable. I have found no other rust on this vehicle anywhere else. Unmolested wiring harness. Stock radio with 200 watt sub behind the passenger seat, I use a FM broadcaster with my CD/mp3 player, works well. New batteryNo AC or power steering. No computer or O2 sensor in the system. Has the jump seats, headreasts, seat belts, ect for the bed. Glass, all lenses are good. Tailgate trim is in good condition. $sold I posted under vendors because I bought this Brat for resale. Required disclaimer: Everthing expressed here is my opinion, as is where is sale.
Would 185/80/R13 fit my EA81 Wagon
Will Smith replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The difference is around 5%. If you are close to an interstate with mile markers you could test for the difference. One mile in 60 seconds is 60mph. Dink around until you get a 60 second mile then you can figure the difference. Don't forget to add this percentage to your gas mileage. -
they fit just fine, they also ride better and last longer too. -
I think I need to disable my choke...
Will Smith replied to GoldDiggerRoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if I'm not mistaken your choke pulloff is an electric heating coil. check continuity of the coil check for power to the coil -
So we ran over a garbage can...
Will Smith replied to MoscowSubaruDude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
2am and high centered on a trash can...now that's funny I don't care who you are. -
pretty sure it does, sending units may be different but I doubt it.
1984 Gauge Cluster questions
Will Smith replied to rainydays's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Some background: this conversion was an 83 4wd GL 10 digital instrument cluster to an 83 4wd GL analog instrument cluster.I never hooked up all the wires. Just enough to get me down the road. You will have lots of wires left over. After you pull the instrument panel you will see three bundles of wires and a green plug all used by the digi dash. My diagram will indicate color and from what bundle the wires come from. The bundles will be numbered from left to right ie: the bundle on the left is number one; center is number two; bundle on right will be number three. The large green flat plug is the furthest on the right. The wires are labeled with the primary(most) color first. Any color after the primary indicates a stripe. As an example a WHT/BLU is a white wire with a blue stripe. I have identified the following wires although I have not figured out where they go into the back of the cluster: 3rd bundle: BLU/BLK LR Door indicator RED/GRN Diode (darned if I remember what this is) GRN Park Brake indicator 2nd Bundle: GRN/BLK RF Door indicator RED Park Lamp There is a white male plug I believe should be pluged into the white female dash light plug. My Brat is currently disassembled so you may have to figure that one out for yourselves or wait until I finish. -
Engine Installaton q's
I had to do that. Just make sure you wipe off the grit before you install it. -
My kinda fix!
1991 Loyale rear wheel alignment
Will Smith replied to rth009's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If I remember correctly, there are no adjustable parts on the rear suspension. Only things I can think of would be the swing arm is bent, wheel bearing is shot or strut is bent. All easy to find at the junk yard. -
air suspension gone splat!
Will Smith replied to Sonicfrog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I converted my air ride to traditional struts, found out the springs on the air shocks were softer than regular strut assemblies. Darn car would bottom out all the time until I put regular springs on the struts. -
I never tried it. Be nice if it worked.
I assume you changed both fuel filters also. You might try taking off the gas cap when this happens, if improved, a vent line is plugged. otherwise I'd guess pick-up screen in the tank in clogged.
Brake pedal makes the shifter twitch?!?!?
Will Smith replied to shigthenewt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If I remember corectly, there is a solenoid which prevents you from moving the gear shift unless the brake pedal is depressed. the jiggle you see is the solenoid dragging on your out of adjustment gear selector. I think. -
as long as the compressor turns easily by hand and the inside of the intake and exhaust ports does not seem dusty(aluminum dust), you should be ok.
Anyone wanna take a guess at these?
Will Smith replied to NewDriverOlderRide's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's been a long time so bear with me here...seems like we used to replace an altimeter on the passenger side of the engine compartment, bout the size of a small box of matches, black with one vacuum hose leading to it Seems like this was on fuel injected engines. Never did figure a way to test them, just put used ones on there until the light stayed off. -
same here, inboard joint.
white smoke means coolant. could be a head gasket or intake gasket.
Need To Tow 1987 Brat - Question
Will Smith replied to aba4430's topic in Old Gen.: 80's GL/DL/XT/Loyales...
other ways of getting your vehicle on a dolly: ratchet strap block and tackle and my favorite a come-along -
BRAT Paint for the ER27TT Advise
Will Smith replied to Gravityman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I for one would appreciate everyone coming up with a design. I am currently painting a Brat with approximately the same silver and blue as seen in above posts. I have tried to come up with something besides a factory paint job(boring). a few tries of mine: Anyone else? -
water in the oil EA81 opinions please
Will Smith replied to Will Smith's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for your help. I took the valve covers off, fiiled the radiator with water. The only place I had any water come out was through the crankcase drain plug. So I assume the problem must be in the head gasket. When the engine runs the water pump must have enough pressure to push the water into the oil pan. Just my guess, will know more later. Thanks again.
