Will Smith
Everything posted by Will Smith
what do you use to remove decal glue residue?
Will Smith replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i use the round eraser fits in a drill, rubs the decal and glue off. -
EA81 backfiring... why she do this???
Will Smith replied to subaru420's topic in Old Gen.: 80's GL/DL/XT/Loyales...
couild be a bad distibutor cap or wires. to check the wires, open the hood when it is dark and if you see a light show around the wires time to change. -
i have a few on my web site, you did not specify what model you have.
I usually get into trouble when I think but here goes, the heads on your engine may still be good. alot of EA82's have bad heads, whole cars can be had for a song, the engine might had for free, use your heads to fix a bad one.
windshield compatability
Will Smith replied to WoodsWagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i doubt it. the windshield post on a three door tilts back further than a loyale. the three door windshield will be longer than the wagon, same width just longer. -
your clutch is a 12 inch
timing belt replacement
Will Smith replied to Dianalee's topic in Old Gen.: 80's GL/DL/XT/Loyales...
don't forget to replace the camshaft and front crank seals also. -
if the seal is retained by a screw-in cup the cup may not be in all the way; is the output shaft loose? Also important to note the seals are directional, ie. there is a left and right side. If you get the sides mixed up it will actually push oil out of the seal, although it should not be too much.
you can adjust the needle. the needle moves because in the back the metal is heated and causes the needle to move. When these gauges were like yours it indicated a direct short in the wire between the sending unit and gauge. Be sure to check the wire for bare spots. you must pull the cluster, disasemble and you will see what to do. Might be you could do it from the front, I always did it from the back, just can not remember why now.
84 gl-10 sedan with digital dash problem
Will Smith replied to davebaldwin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
here is where I either look like a hero or a .... I have posted a file on my web site called Digital Dash Conversion.zip link: http://willsmith.dtdns.net/Digital%20Dash%20conversion.zip two jpegs and a text file. shows the pin out on the analog dash. Helpful suggestions welcome. Will -
10-4 shall do. -
I could post the harness diagram to convert a digi to an analog if anyone wants to convert like I did. -
anyone ever get a response from CCR?
Will Smith replied to Humble Nuto 53's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I got a reply only took a week. Prices on an EA82 SPFI is $1295; price on an EA82 T is $1795. add shipping to both of around $150. -
you will need the pin out diagram for both dashes. then just figure out which colors you need to connect. as an example figure out which wire from your digi car goes to your gas tank sending unit then figure out which plug on your new analog dash is for the gas gauge, connect them, move on to the next gauge. I have done the conversion albeit only on the gauges, dash lights and 4wd indicators. I did not connect the open door, light indicator, and clock side of the cluster. After 6 hours I had had enough. All the sending units, speedo and tach worked just fine. The cost to repair a digidash is around $250.
Insurance Question
Will Smith replied to lepetitprince's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The condition of the vehicle is for the most part irrelevant when purchasing liability insurance. The condition becomes important when you need collision/ damage. Liability only pays to fix the other guys vehicle, you eat your own repairs. Call around on the phone and internet for quotes, be upfront and tell them you are new to all this and you want a quote for liability insurance at the minimum coverage required by the state(unless you have lots of assets). -
converting a 1984 GLF Sedan to a wagon.
Will Smith replied to warfride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
replacing panels is lots of work. You could instead do what is know as a "top and tail". Which is cut the body in the middle of the windshield posts and across the floorboard under the drivers seat. Remove the back half of the car and replace it with the back half of the wagon which was cut in the same place. A little welding and some other finish work and you have an wagon with much less work. -
What is this exhaust thing on my EA-81??
Will Smith replied to Hocrest's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have done the same thing many times myself. Your Y-pipe is from a different model. You need that spacer because your Y-pipe will not bolt up properly without it. The tube on the spacer is pinched off if I don't miss my bet.
