About TOONGA
- Birthday 10/20/1965
Gender
Not Telling
Location
Australind
Interests
eating, sleeping, living and annoying my children
Occupation
classified
Ezboard Name
n/a
Referral
AUsubaru members who hang here as well :)
Biography
classified
Vehicles
lots
Contact Methods
Skype
toonga65
Recent Profile Visitors
TOONGA's Achievements
USMB is life! (4/11)
13
EA81 exhaust... so this happened...
TOONGA replied to Knucklehead Saloon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
your primary jets are way too big for an EA81, unless it has a worked cam. I would suggest a 135 -140 primary and a 150 -165 secondary and go to a 50 idle on the primary and a 55 on the secondary. If you can get them got to 3.0 or 3.5 venturis as well, as the standard 4.0 or 4.5 venturis the webers ship with are too big for the EA81 as well. Given that the CFM of a 32/36 is between 290 to 350 (depending on the model) and EA81 Hitachis are between 130 to 190 CFM (depending on the model) you are always going to overfuel. Remember as well US fuel has a different RON rating to Australian camel piss Good luck with it TOONGA -
Source for double row full metal radiator
TOONGA replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Xt6 radiator has a twin core EA82T doesn't, mine didn't on a Vortex XT EA82 turbo. The XT6 radiator will fit but the outlet pipes are bigger 38mm. I know people in Australia that have bought these chines ally radiators, some fit directly others state they have to modify holes for the radiator fans and body mounting screws. When you search ebay, do you use the international options or just America? As for the sellers you will find they have more than one store that they sell from. Just like the sellers who sell oem phone parts. TOONGA -
According to the parts catalogues I've checked it is called the F WHL apron front (left or right) / Brkt F sus comp (left or right). which I guess translates to front wheel apron (left or right) bracket front suspension complete (left or right) there is a very good list of manuals for imprezas available here http://ken-gilbert.com/impreza-manuals all models here http://jdmfsm.info/Auto/Japan/Subaru/ Good luck with it TOONGA
Ebay? These are in Autralia not sure of the cost of shipping to the USA http://www.ebay.com/itm/NEW-FULL-Aluminum-Radiator-FOR-SUBARU-LEONIE-L-SERIES-WAGON-1-6ltr-1-8ltr-85-94-/262168238151?hash=item3d0a71d847:g:Os8AAOSwAKxWW~25&vxp=mtr http://www.ebay.com/itm/HIGH-PER-Aluminum-Radiator-FOR-SUBARU-LEONIE-L-SERIES-WAGON-1-6ltr-1-8ltr-85-94-/151950795342?hash=item2360f9224e:g:SNwAAOSwv-NWVrnx&vxp=mtr http://www.ebay.com/itm/FOR-SUBARU-LEONIE-L-SERIES-WAGON-1-6ltr-1-8ltr-NEW-85-94-Aluminum-Radiator-BEST-/281875123765?hash=item41a1110e35:g:V90AAOSwwE5WYSj9&vxp=mtr TOONGA -
Check this out! DUAL Carbs
TOONGA replied to SteelyDel's topic in Historic Subaru Forum: 50's thru 70's
It would not fit as the 1600 manifold is shorter than the 1800 manifold, I found out the hard way . Unless you have a 1600 in your brat that is. TOONGA -
XT6 rear hubs EOI in 5x100 & 5x114.3 ?
TOONGA replied to dfoyl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes I'm interested not sure what I will need to sell to afford them but hey TOONGA -
They look great really good in fact. any news on price and availability? TOONGA -
So I did a little search on that alternator and found this http://forums.nasioc.com/forums/showthread.php?t=1323800&highlight=EZ30&page=113 it may help you. I still believe the alternator is on, hence the noise you are hearing. I have had the same problem with an EJ22 in a brumby and an EJ22 in an XT / vortex. Both times the problem was fixed by changing the way the alternator was wired. TOONGA
If this was an EJ engine swap into an EA older vehicle I would say the alternator is making the noise. This is because it is wired to permanent power (EA alternator) not switched power (EJ alternator). As I have no idea what car the alternator / engine is in this is the only advice I can give you. TOONGA
EA81T, 3AT, ATF spews out the dipstick tube
TOONGA replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are the breather tubes on top of the 3AT working? sounds like a build up of pressure of some sort in the box is causing the fluid to vent. How much ATF fluid is in the box ? Too much fluid could cause this to happen. Does the box have an ATF cooler in front of the radiator? check that it isn't blocked. TOONGA -
You can use outback or forester trailing arms as both are longer than the impreza arms the outback are longer again than the forester arms from memory. Looks like a great project good luck with it. TOONGA
4wd diff lock not engaging
TOONGA replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The big diaphragm on the side needs full vacuum from the inlet manifold to operate. the easiest way to test it would be to bypass the solenoid. With the engine running have a hose run from the diaphragm to the inlet manifold, if it is working the diff lock lever and cable will move if it isn't the lever and cable will not move. Check the switch for the diff lock on the side of the box it could be that it is faulty. With the stater motor out the diaphragm is easier to get to. TOONGA
