Alex C
Everything posted by Alex C
  1. FSM=Factory Service Manual. I knew that much. But where do I get them and how much? Alex
  2. I went about online checking part numbers, I only found one different number, the 1982 GLW has different axles for the 2wd, but the 4wd has the same axles as every other model. I just have a GL but I wanted to make sure. Alex
  3. While I drive an EA81 auto ive put the better part of 100k on my car at around 4500 rpm. No problems for me. Also those kit builders that use ea81's liek to gear it so that the engine is at 5000 rpm for the flight, as that puts it at the top of the power band and you get good fuel usage out of it. Alex
  4. HI, I have a question that us locals were unsure of the answer to. For an EA81 car are their any differences between front axles for the different tranny types? (I am aware of the beefier front axles for 4wd). Do they all have the same spline count? Are they all the same length? thanks Alex
  5. Easy, tell me your exact tire measurements, your 5th gear ratio, and your diff ratio. we can easily find out how fast you are going by doing some math. I used the same techniques to determine how much slippage there is from engine to wheel with my auto tranny while driving at 4k in drive on the freeway. Alex
  6. I ended up with a gm style big cd player, I put it in the tray at the bottom of the console. I can just remove a disk when the shifter is in park. I think it worked pretty good, plus its not at an extreme angle, which will damamge cd players or cause them to not work right. I think you dont want to go over 30 degrees max. Alex
  7. An external cooler is a mini radiator made for the auto trans cars (other applications as well). It has brackets that attach it to the front of your radiator and you move your tranny cooler lines to it from the radiator. The line for the tranny fluid through the radiator is pretty meek, and doesnt do much. The cooler will keep it much cooler. I think most parts stores will have them for about 30 bucks. I know Napa definately does. Alex
  8. think of the extra hole for the hood brace, so you can open the hood farther. they new you might need to fix it and just made it easier. Makes more sense than making it impossible to repair. Or the plugs in the front frame members that allow you access to the two long head bolts on each side so you can take the heads off without removing the engine. Great design ideas. Oh yea, the tool kit that is provided, a very nice touch. Do they still do this in the new cars? Alex
  9. Mine gets hot, but there isnt a warning light considering its age (82). Mine also gets hottest at stoplights. However, the problem is similar, change to a external tranny cooler, which is what im doing. Alex PS, mine is over 4 on the freeway too if im going faster than 68 mph.
  10. OK, this sucks, I cant make friday nights. I have a standing prior commitment. Only saturdays for me. :-\ Alex
  11. Bad news, I just came from downtown medford, its all blocked off, cant get closer than tenth of a mile (few blocks). I am called it a day after trying to fight traffic for 20 minutes to get there and went home. We should have met at 6 when the streets were still open, but I know that wasnt possible. Ideas for the next time??? Alex
  12. I guess it will be at the al's hobbies at 8:30?
  13. sounds great, just someone bring a cell phone.
  14. So how are you guys doing mp3's? specific stereos for that, or some weird adaptation like i did? Ill be there sat night.
  15. we could always order pizzas. Im sure they would deliver in town BTW, I dont have a very loud fuctional stereo for my car right now but it is rigged to play MP3's, so feel free to bring mix disks.
  16. that Im not so sure of, But my manual ( haynes? or hayes?) said that I needed a machine shop to remove and replace the bearings. they have to be pressed out and pressed in. Obviously I didnt have to do that.
  17. ok, lol, so lets get it set up? adam PM me so we can get the details going. Then Ill have everyone else pm me for specifics or Ill post it here?
  18. LOL, forgot about that. I guess getting the sodas would be a trick eh? and working on his cars would also be hilarious ok, anyway, lets find a time and a place. Alex
  19. OK, so we need directions adam? and the date (the 19th?). time would be after 6pm? sodas and wrenching? Alex
  20. yes it was a good burrito. J/K Ayway, I started my car tonight after not driving it for 2 hours, and a huge cloud of smoke came out of the exaust. Bluish in color. It hasnt repeated in the one start after that. It smelled like unburnt gas, not like oil, even though it was blue. I was parked on a hill with the drivers side down, but ive been parking like that all year and ive never had this happen before. The motor was rebuilt about 6 years ago (almost 70k miles). Alex
  21. HI, I was referred to you for a brush gaurd, what sort of money are we talking about for one in the classic sub style? I have a 82 gl 4-d sedan
  22. yep, six for me too. I guess mike didnt tell you, I got a job at harley davidson for parts and inventory. I start wednesday morning. PS, the tranny is getting worse, so let me know when we can do that, and what parts we need that you dont have already. Alex
  23. Of course, now that i want to do this I realized my new job requires me to work not only sat but sun too. So maybe after 6pm?
