I came across this BRAT while looking for a replacement driver when my 86' GL Wagon went down after loosing the left rear hub at 40mph
The BRAT is fairly clean, does have some cancer but mostly all the issues it has is from neglect and not so much abuse.
I noticed an issue with the clutch when I test drove it, several times, but had figured it was similar to problems I had had on my GL, (new cable and proper routing) so was not too worried. I put a couple K's on the car shaking it down and everything else seems to be in good shape, (less a noisy,incorrect? fuel pump) The engine seems much stronger than my GL and it is a fun lil ride I hope to refurbish into a reliable driver for my daughter when she starts high school in a few years.
I adjusted the cable at the tranny and was able to improve the clutch action for a period of time, but it always returned. Finally decided to pull the cable and see if it was the cable or routing or...?
What I found was that the "gusset" or "support" that the clutch/brake pivots attach to as well as where the clutch cable housing mounts to, has a crack which allows the support to fold or bend when the clutch pedal is pressed.
From what I can see this is just sheet metal, maybe galvanized??? and is spot welded in place.
Originally I thought I could make a backing plate from some real metal and bolt up from the opposite side that the cable housing and pivots attach. Yesterday I was going to start removing parts to affect the repair and noticed a "stamped", "raised" area, that would not let a backing plate sit flush against the support and decided to rethink the repair.
I have done lots of looking around here and other places but have not found any mention of similar issues so....hopefully some one will read this who knows what I am referring to and perhaps has experience or at least some ideas.
I will try and get some pics of the problem area today as well...
TIA
Scott
