dadpups
About dadpups
  • Birthday 08/25/1939
  • Location
    San Antonio
  • Referral
    thermostat
  • Biography
    Geologist and car nut
  • Vehicles
    01, 02 Forester S, 86 GL
dadpups's Achievements
Member
Member (2/11)
  1. My car has stopped shaking. Waiting for it to happen again. If it ain't broke.... Seriously, I have not had the time to check calipers. Will report when I do. Thanks for all the replies!
  2. At 60 mph the steer wheel will start shaking something is going on in front suspension or drive train. This happened occasionally until yesterday when it was quite severe. Shaking went away on brief deceleration back on acceleration. Of and on gas off gas on. At 40 mph its gone. Thanks, Roger
  3. Looking for recommendations, experiences. 2002 Subaru Forester. Thanks, Roger BTW is my car ISO 14230 compliant?
  4. GD, thanks! Is this what you mean? http://www.webercarbsdirect.com/32_36_DGV_p/22680.005.htm Does it just pretty much "drop in"? Or do I need what appears to be a pretty costly conversion kit? Thanks, Roger
  5. Hi GD, I read in some earlier post that you have some tips for a Hitachi Carburetor # DCZ328 rebuild. Any that you could pass on here will be much appreciated. Roger 85 GL 4WD Wagon
  6. Oil Pressure Switch for a '76 Olds Starfire and it's wiring connector.
    3 contacts on switch, 1 for oil light, 2 for fuel pump power.
    No Oil Prssure, no juice to fuel pump.
    Do need to fashion an adapter for switch-oil pump mounting.
  7. GD, many many thanks for the great reply. Will probably go with the third option. The previous owner installed manual choke so no problem there. I sure hope this forum stays up!!! Cheers, Roger
  8. Hi Tom, Seen some posts of yours about FPCU workaround but can't seem to find them again. Can you point me to them? Thanks, Roger 85 GL 4wd wagon.
  9. 85 GL 4wd wagon. Need fuel pump control unit aka FPCU aka revolution sensor part no 22631AA000 also numbered K8T65072 with mitsubishi logo or instructions on how to fix/replace. Pic of inside attached. How can anything be so complex??? http://hydroweb.com/rev.jpg
  10. Can I get more info on search terms for ebay kit? Thanks!
