Jerry Robinson
Jerry Robinson's Achievements
Newbie (1/11)
0
If you read some of the postings on turbo EA82's they had their share of problems, so your only going to get a little bang for your bucks. If your looking for a daily driver then I would look for a non turbo engine. The people to ask would be GD and Miles Fox, as they both have experence with the turbo engines. Heres a post that you may want to read and/or follow.
http://www.ultimatesubaru.org/forum/showthread.php?t=126592
Ed
Greetings:
I have a couple of questions for ya if you don't mind. I have a 1986 Loyale wagon w/ Turbo but the engine is toast. Body is very good.
I'm either going to rebuild this engine as a non Turbo with non Turbo Cams and pistons.
Or I can pick up a used ea82 non Turbo carberated engine w/ 179,000 miles.
Then I thought I could use the Turbo heads from my engine to get the 135 hp +-.
Pros and cons would be less initial cost, ($250) for the engine plus gasket set. But I would start with a used engine. ???
Rebuild on my engine would be $550 +-.
Will also put in a dual range trans.
Any thoughts suggestions or ideas are more than welcome.
Thanks for your time and knowledge.
Please respond via pm or to my email skyhookblinds@gmail.com
Jerry Robinson
Grayling,Mi.
989-390-1683
