pyropyro
Everything posted by pyropyro
Well, things have dried out in the cabin, humid weather is over for the time being. The tach has behaved perfectly ever since that one incident a few days ago, so maybe that was it. Wer the alternator of battery causing the irratic tach behavior, wouldn't there be other symptoms as well? (I'm not aware of any)
2003 Outback, 75,000 miles (really was a little old ladys car) Automatic trans. I've been driving it a year, typical problems, but runs great. Yesterday, about 1 mile into a 6 mile round trip into town and back, I noticed the tach needle flitting about, dropping to peg, then working properly for a few moments. Very eratic. I pulled over and put trans in park, revved it to 4,000 RPM for a few seconds, and then it worked fine for the rest of the trip. What might cause this? I wondered about conditions. It's been below zero at nights lately. I've tracked snow onto the floorboards, and gotten a lot condensation on the inside of the windows which frosts over night, then when the car warms up turns to water to mopped off the inside of the widows with a towell. Run the air condioner and heater on high with defrost. Shooting in the dark there, I doubt this really has anything to with the tach.
Oh, it leaks oil too. But not so much that I have add between oil changes. Not yet anyway. Excellent discussion guys, I can't thank you all enough for the insight/experience/opinions. And even those who exclaim "Don't drive it!!" I appreciated the enthusiam. I love these cars. I I have two EA 82 parts cars sitting behind the house, donars that kept my lifted 1985 wagon on the road for over 10 years. Sold it when I inherited this Outback. Kind of wish I still had it. I WILL get this Outback in top shape, I WILL!!
"find a good and cheap indy shop,--------(snip)" I know your not joking, but really? It's my thought that there is no such thing. I fear I'll have to try to do it myself. I'm no novice to "back yard' wrenching, I"m 60 and have always maintained my own vehicles, but I'm far from an expert. It's moot right now, has to wait untill the coin is saved up for parts. Need belt and front reseal too. What I wish I could get my head around, or get some sense of, is how fast these "seeps" can, or are likely too----turn into gushers. I don't even know if they do. Turn, that is. Mike03, your not the first person to have mentioned that many simply don't pay attention and thus overheat and kill the engine. I do pay attention, but I simply don't really have an idea of how fast an EJ 25 (2003) headgasket seep is likely to escalate into catastrophic failure. I'm getting the sense after years of study here at USMB that it tends to be a slow proscess. I hope so.
When I got the car a year ago, it was a seep. Both sides rear. It was driven from Albany OR to Bend, which lowered the level in over flow maybe 3/4 of an inch. I topped overflow off and every hundred or so miles had to add coolant to over flow. After a couple hundred miles, I drained system, replentished with Subaroo coolant and added one unit of conditioner. Slowed it down immediatly. After maybe a couple hundred miles, on advice from forum members, added one more unit of conditioner. The seeping stopped for several thousand miles. Now it is seepeing again. This car had never been overheated. (It's been in the family forever, I know it's history) I watch the temp guage like hawk, but don't know how fast these issues can escalate. It's still only seeping, and only on one side now. Thanks for the conversation guys. I kind of have no choice but to try to keep it on the road over the winter, but this upcoming trip really worries me. I'll carry plenty of water and coolant.
I don't know about "loose radiator cap". Have to think about that. I was just wondering about the Factory Coolant Conditioner. (stop leak) Bear in mind, I was NOT considering adding another unit of the stuff to the radiator as is. Rather, draining, refilling with new, and then adding the "conditioner". The question in my mind, might doing it that way avoid a "cumlative" effect. No more that the one, or possibly two if one didn't work, measures of the conditioner would be circulating thru the system. I may have take the car on a 300 mile round trip soon. I figure it would HAVE to be bad to add more to the system as is. There is already two units in it now. Another would make a total of three. That can't be ok. But to drain, then add one unit of the stuff? I don't know. I sure don't want to kill the radiator.
Inherited moms car at 75,000 miles right around 12 months ago. As is common, the HG seeped a bit. This was a year ago. I don't drive much. And am poor. I drained cooling system, Put in Soob coolant and one Soob "conditioner". Still leaked. Started thread here about it. Was advised adding ONE more Soob conditioner. I did, and it has not leaked for around 2000 miles. It's now leaking again. I can not do new gaskets at this time. What are odds that drainiing, installing new coolant and conditioner might get me another couple thousand miles leak free miles? (or ANY leak free miles, for that matter?) I'm saving my pennys for the HG job, but just not there yet. Maybe next spring.
Have not had this car long. 75,000 miles on this the clock. Will run great for a while then starts running on two cyl. Let it sit overnight, runs good agiain for a while. I checked plugs, Not too bad but clearly too old and need replaced but have to wait till payday. (two weeks) Having codes pulled a local NAPPA) She has failed valve cover gaskets, the O rings for plugs leak, plug wire boots oily. Some valve cover bolts were not very tight, tightening didn't seem to help. Do we think likely culprit is oil shorting out plugs? I will throw new plugs and wires at her on payday, what are my odds of success?
In all my searching USMB and the google machine I had not seen mention of using two of the Subaru coolant "conditioner". (stop leak) My first impulse is to feel reluctant, since I HAVE seen more than a few debates regarding weather or not the stuff is bad for radiators, or is fine for them. After reading quite a few of those debates, I concluded that there was close to a consensus amongst the old hands that the conditioner was in all likelyhood not harmfull to radiators. So that was my first impulse. After sleeping on it, I still feel reluctant. Time to do some more reading, see if the google machine or USMB search will reveal debates and comments about doubling up on this stuff. Of course comments are always welcome by me, I did ask.
I want to thank all who have responded. You guys have taken a load off my mind. Especially it's nice to see some familiar, trusted names from quite a few years ago still here, guys whos advice and tech experience helped me build my 85 wagon into a lifted dayly driver that stood by me for close to a decade. Thanks again. I'll be around.
Thanks for reply. Ya, I changed the coolant the day I brought it home. Used Subaru coolant and added their "conditioner". What I took out looked exactly the same, darker forest green that your average coolant, just like the real thing. There was also obviously the "conditioner" already present. I am going to have gamble on the timing belts holding out thru this winter. I just can't do it now.
I took my recently aquired '03 Outback to dealer for recall service "Parking Rod". Took 5 & 1/2 hours total, they had told me 3. (ok, done bitching) At one point in the middle of this, they called me back in to show me something about "your car". I had a guess. Yup, head gaskets leaking. (externally) Single OHC. (phase II correct?) 70,000 miles. The guy was asking if I wanted to have it done now. Suggested also do timing belts and showed me an oil leak at timing belt cover, lower just right of center, said was "piston plug gasket" I know it's time for new belts and complete front re-seal. It's just that there is no way I can do this untill next spring. I will have to do it myself, I do not have 2 grand to spend. I mentioned I would have to do it myself, but what gasket would "they" use, MLS or what? No, single layer. Yet I have seen (I think) reference to a SUBARU MLS gasket for the Phase II EJ25. I'm obviously confused. Most here indeed recommend only using Subaru headgasket, though there are threads debating a "5 star ?" MLS. But that's not my question. If ask subaru for a HG for this car, exactly what are going to sell me? The same thing that is now failing, or an upgraded version? AND: It's not using a lot of coolant, very slow weeping. I need to drive it maybe a couple hundred miles per month, if that thru this winter. I know there is no way to predict the odds, but I AM interested in hearing speculation as to if I might suceed in making it untill next spring. Thanks for any thoughts
Well, I guess I shouldn't be suprised, but I'm pretty pissed anyway. I just realized that I've added water to the over flow twice in a couple of days. That with just around town driving, prolly not more than 40 miles. Crap. It has begun. The last few years of driving miles on this car were literaly "little old lady" miles. Short runs and then sitting for weeks. Exactly the type of miles I have been warned about for the head gasket problem. Hope I find a loose hose clamp, but I'd bet I don't.
Thanks for the reply Fairtax. Much appreciated. I am expecially glad to hear what I THINK you are saying, that this is a dependable trans. (The EA cars had crap auto trans, as many of know) Regarding the timing belts, I wonder why the heck Subaru ditched the Non-interferance, for Interferance. Manufacturing costs I suppose. Not that I know, I just suppose. I appreciated the tip to get those changed out. It can't happen untill next spring. Niether finances nor time will allow it. I guess I'll just have to risk it for now. I dont feel it too big of a risk at this point, at least I hope not. Besides, we are not likely to put more than a couple thousand miles on the vehicle between now and then. But I take your point, and will get it done ASAP. Also I am greatfull for the info about the headgasket issue. I had gathered pretty much what you are saying from general reading around the web and here at USMB, but it is nice to have it confirmed by you. We will certainly keep an eye on the coolant level and the temp. This motor is exceptionaly clean for the miles it has. I see no indication of any oil or coolant anywhere on top, though I have now looked underneath as of yet. (I know it has never been washed under the hood.) So, we will keep an eye on the front lower corners, check coolant levels frequently, and keep eye on temp. Trans was serviced not long ago. Thanks!
Greeting Soob fans and my old friends at the USMB. A brief re-into for ya'll: I was here in the old school section for several years way back when, when I first fell into an 85 GL wagon. Due to living on a long country lane with no snow plowing happening, I allowed friendly folks hear at the board to advise me on how to lift that wagon. It has been my beloved dayly driver for around a decade. A big thanks to all my old friends here for all the help. So why am I writing in the New Generation section now? Cause my dear old mum has aged beyond her ability to keep driving. So----after my brother and I noticed yet ANOTHER ding in her 2003 Outback, we had a family pow wow, and she has seen the light, and moved into an assisted living home. Her quality of life will improve from this. AND, she has seen fit to beqeath her Outback to ------me. I took possession off this Soob yesterday. Have driven it all of 10 miles. A huge upgrade for my wife and I, and much to learn. So, a 2003 outback, with 69,000 miles. EJ 25, Auto trans. She bought it from Hertz Sales in Bend Oregon with maybe 40 or 50 thou I think. Has had pretty good maintenence since she bought it. I just have not had time to do much research, but I do gather that there were head gasket problems. I think I am reading that these issues were partially addressed with the EJ 25 by 2003, is this correct? I gather that I am more likely to have external leaks than internal, yes? No? Maybe? And if so is there some average amount of miles before these HG issues arise? My other concern is regarding this automatic transmission. Plate under hood says Trans: tz1a4zceba. So, what is the reputation of these units? I would MUCH preffer a manual, but oh welll, "gift horse in the mouth" and so on and so forth. The tires have lots of tread, but they look more like street tires than snow tires, which wont do where I live in La Pine OR. I see that timing belts interval is 105,000 thou, so I guess I don't need to worry about that yet. Just change the oil and drive it I guess. I would love to hear advice, tips, warnings-----whatever. I know my old EA like the back of my hand, but this beast-------all new to me! Anyway----it's good to be back, always did like this outfit. Thanks! Pyro.
Hey guys. I used to hang over at the Old school board, those guys taught me how to do a tranny swap and a lift on my 85 GL. She's my dayly driver for all these years, and I lover her to death. But why I'm back is in the title. I know next to nothing about anything after the GL/Loyales. My daughter needs to buy a car. She has 4 grand tops. I have her convinced she ought to buy a Soob. She believes me. We both like the looks of the Foresters better than Outbacks, butlooks aint everything, I know. So we find a few Foresters in our area, in our price range, mostly in early 90's. The really start looking at reviews, and I don't like what I'm hearing. Are there some inherent probs with the first Foresters? What about second Gen? So, wikapedia tells me which generation of Forester started when, and such. Gen two might be out of our price range. So should we be looking at Outbacks? Guess what I'm asking for is some tales of inherant problems in ceratin years, Forrester compared to Outback, which years to stay away from if such is the case. She wants a manual trans, and I'm glad of that. I recomended a Soob to her because of my old ones Deadnuts reliability and ease of maintenece all these years. I'd be doing 99% work on her new/used car. I want her to get the best bang for her buck. Can't thank y'all enough for any and all tips/tricks/advice/warnings/storys/anecdotes/tales of woe and or victory, whatever. I'm listening. Pyro in Lapine OR
