About Arty
- Birthday 02/15/1976
Gender
Male
Location
Cincinnati Area
Interests
Music, aviation, cars, computers
Vehicles
95 OBW 2.2, 06 Legy iLimited Wagon
Arty's Achievements
USMB is life! (4/11)
0
Update- Just went to a local mechanic to see if they'd be willing to flip the u joint for me (I really don't want to mess with this if I can avoid it at this point) and I was warned that the clock spring in the steering column is out of phase now and he'd have to take the whole thing apart to put it back together correctly, because if not, the airbag will deploy and kill me. I get this feeling that that's not entirely true, but if it is, someone please let me know.
Wow, it's been a really long time since I've posted here. Anyway, the title says it all- Are the u joints of a steering column (in this particular case, a 2006 Legacy 2.5i Limited wagon) directional? I ask because I had to replace the steering rack on my car and when I finally got everything buttoned up and aligned well enough to go have the alignment done professionally, I was horrified to realize that the steering wheel was now upside down. What did I do wrong? Please, someone tell me there is a quicker way to fix this than having to go all the way back to having to lower the steering rack again to uncouple it from the u joint and turn the wheel 180 degrees.
Since I ran into an issue with the new water pump I installed being faulty, I'm going to kill some time by taking off the oil pump again and redoing the seal. But here's my big question- How on earth am I supposed to get the oil pump free from the grip of the ultra black? It's putting up a very impressive fight
My Dremel did nothing for me, unfortunately. All it did was bounce around the hole. I was worried about causing more damage to the already bad area. I'll call the machine shop tomorrow and see if they're willing to not be jerks and help me out. Though I usually find that some guy with a Subaru and a stupid problem is generally treated like garbage at places like that, and I am just not at all in the frame of mind to deal with that right now. Maybe if I just buy a really big c-clamp...
I was considering adding a new bolt, but I don't want to compromise any more strength from the block in the process. But this car isn't our only source of transportation and money is ok. But, yeah... saving the hassle would be nice. There is a machine shop super close to me. Maybe if I go bother them long enough they'll consider letting me drop it off there and taking care of it for me. I've done this timing belt thing enough times that I could probably drive there (maybe a mile and a half at the most), tear it down to where they need, have them do their thing, and then put it back together to drive home and totally finish then. Who knows. All this over a freaking bolt. A single bolt. One of my cars uses lasers to match the speed of the car in front of me while the computer changes the suspension settings thousands of times a second. And then there's this bolt...
Yeah... they are pretty pointless. But it was good for the placebo effect. I have actually had extractors work a couple of times, but never in a car. But you know what works surprisingly well for stuff like this? Vampliers. I knew last night that I'd be ok with two broken bolts because enough of them was left sticking out that I could lock my Vampliers on them and pull them out. And I was right. But the one on the oil pump, man... it put up a fight and it won. One of the only times my Vampliers failed me. Buy Vampliers.
Actually, yeah, you're right. Crap. I didn't even think of that for some reason. Thank you for pointing that out, because I never would have seen that. There are two more problems with this, though- 1- The bolt is long gone by this point. It's just the back end of the extractor now. 2- I don't own any welding equipment and, for reasons I can't really get into, I can not be even remotely close to welding equipment. That being said, I think I've more or less resigned myself to the fact that I'm going to need to look into getting a new block soon. I was planning on actually buying an engine to rebuild just to have around, so maybe this is the reason I needed to do that. This particular engine is already in pretty rough shape, so if this is what does it in, then at least I know what happened. Meanwhile, I have a '95 EJ22 with over 200k miles on the clock rusting out with a giant hole between the IAC valve and block and it chugs along like a tank. Funny how some things go.
I tried many different ways, nothing worked. I'm starting to wonder if there was possibly something wrong with the threading in the bolt hole before I put the bolt in Yeah, I've decided that the extractor is part of the block now. The bolt is the second to bottom on the left side (if you're facing the front of the car) on the oil pump. I can't help but think that there is a way to work around a missing bolt, especially on something with so much torque already holding it down and with such a heavy seal around it like the oil pump's gasket. But I guess we'll have to wait and see. I hope it's fine. Otherwise it's time to order a short block.
I come to you all with great shame, so please go easy on me. I managed to snap two of the mounting bolts for my oil pump today. This was after torquing them all down and obviously after applying the gasket maker. All the other bolts are fine. So here is my question- Can I make it by with those two bolts missing? I can't help but think that the other bolts are sufficient in terms of tightness and location to keep the broken bolt holes sealed with the gasket maker in place. If I CAN get by with it, how long do I have? I really can not go without this car for any real amount of time. The car is lightly driven about 20 miles a day, give or take. Please tell me I'll be alright until I'm able to go in and fix everything... please?
