Fubaru
About Fubaru
- Birthday May 16
Gender
Male
Location
Top of VA
Interests
All things outdoors
Occupation
Sales
Biography
I refuse to merely exist but rather insist on living.
Vehicles
97 OBS, lifted 95 Impreza, 95 legacy
Fubaru's Achievements
Advanced Member (3/11)
4
I swapped an EJ22 into an EJ18 car and kept the EJ18 I.M. I snapped one of the fittings off this "vac solenoid" and can't find a replacement or part number for the life of me. I'd rather replace it than glue it. Also, if anyone knows what it does exactly, that would be nice to know. It sits on the pass side of the manifold, just above the purge valve (at least that's where it was mounted when I got the car).
The wife's 2015 Outback 2.5i Premium w/150k is currently at the dealership with an EPB warning light on and an issue with the left rear parking brake sticking (the recall was already fixed). The service desk claims the VDC hydraulic unit and the right side of the harness needs to be replaced. From what i've researched, the EPB is entirely electronic/mechanical on this vehicle and not included in the hydraulic system. It also makes no sense to me that the right side harness would cause left sided failure of the system. It's not having a stroke. Part #s- VDC H/U #27596AL00E & harness #26018AL02B. If anyone can confirm or deny the service desk's claim I'd be more than appreciative. We really don't have $1200 to flush right now.
Three weeks of fighting wiring issues and a stupid simple clutch problem and the beast breaths fire. Engine is in and pretty well buttoned up. There's some interior and exterior body mods to make it driveable and we'll be shttn in cotton.
Help! EJ18 to EJ22 swap, leftover electrical connections
Fubaru replied to Fubaru's topic in Subaru Retrofitting
I'm seriously out of ideas and I'm sure I'm going to feel like a moron when the answer arises.... if one arises. Edit: Confirmed - I feel like a moron.... Fixed: The cable was not installed correctly nor adjusted correctly before I bought the car and we left out the small plate between the flywheel and crankshaft when we installed the clutch. The clutch now seems to function as it should. Thanks GLoyale for your patience! -
Got the TB put back on in what looks like the correct manner. It seems like the TB isn't reaching the pressure plate. I've hit a wall. -
The engine is back out. The throwout bearing appears to be incorrectly attached to the release fork and has what appears to be excess play on the input shaft. -
I feel like I'm probably missing something stupid but here's the layout... The 2.2 came from a donor car that had an AT. The torque converter was removed and the clutch pack inatalled. That engine was then inatalled in the car that had a 1.8 and Manual trans. We never pulled the TO bearing off the trans shaft because we weren't replacing it. I apologize for making that sound more complicated than it is. -
GLoyale, I tightened the clutch cable adjustment to the max with no change. The pedal is very soft and doesn't feel like it's engaging. -
I reset the timing and the engine started. I also found the loose wire in the plug the was keeping it from kicking on the fuel. I guess that needs a new plug spliced in. New issue, the trans won't shift into gear with the engine running. Maybe the throwout bearing isn't reaching the pressure plate for some reason?? That seems a bit weird. -
I used the hash marks but I also installed an aftermarket crank pulley and I'm unsure if that could be set wrong. I too thought it was odd that the bracket grounded the harness. I'll revisit the timing also. Thanks! -
Ok. Everything is hooked up (as far as I can tell) and I'm getting a crank-no-start. It wasn't getting spark until we bolted down two brackets that held electrical connectors on the passenger side where the engine and trans mate up. Seems like an odd ground but I now have spark. Cam gears have the same number of teeth on the rear and I swapped out the cam sensor with no change. Didn't set the timing correctly, perhaps? -
Sure was. Thanks Gloyale! It's a 1.8 manifold that matches the car on a 2.2 from a donor. Neither car/exhaust has a downstream 02 sensor so I guess that plug is obsolete??? -
- Fixed - I'm almost positive this has been discussed but after hours of searching the boards, I'm at a loss. I swapped a 95 ej22 into a 95 ej18 car. These 2 electrical connections remain unattached and I'm uncertain if they were ever attached to anything. Any help would be appreciated.
Roof vent done... and for comparatively cheap. The engine is on hold due to missing one flywheel bolt. 8 new ones should be in Tues. then the engine should be going back in.... hopefully.
