Everything posted by MaddCelt
1981 GL Brat. Manufacture date 06/81, EA81 engine #762670. Original motor.
Getting to break down my first EA81
MaddCelt replied to MaddCelt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm hoping that there will not be a need to drill. I just watched a video on how to use one. -
I looked at one of those at the part store. I take it it bores the hole out large enough to fit on of the inserts into the hole, thus replacing the damage? -
Oh joy!!! NOT! Engine had been running rough and felt like it was missing. So I pulled all the plugs. One (of course being the one behind the alt) was loose when I pulled the wire. Checked it out and tried to reinstall. When I tried to rethread it it would be at the wrong angle. Pulled the alt off and got a better look. Damed threads are pooched! Tried to clean them up, no better. So this leaves me with only one option, pull the engine, tear it apart so I can see about getting the hole redone, or find a replacement. Either way it's going to kill what little excess finances we have. Bloody Hel!
Going to have to rethread a plug hole. Looks like one was loose and did some damage to the threading. Cleaned up old and new oil off engine parts. Remounted the jump seats for the kids to play in the back. Repaired a plug wire that I pulled the connecter off. You know, I need to quit tinkering. Every time I do I have more things to do on it.
What Would You Give for This Brat?
So my thought of no more that $200 isn't that far off. I'll be calling him again soon and letting him know that I'll offer him no more that $100 depending on what I see under the hood and underside if he wants to clear it out. I could use the parts and at the very least it will give me something to learn on that will not leave me having to drive the wife's Jeep if I mess up. I took a spin on Google Earth to see haw far back the car shows and at could make it out in the same spot for at least 7 years. -
Compiling database for Gen2 Brat sales evaluations
MaddCelt replied to edrach's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I know this is a bit off topic but I am curious. According to Wiki it is said that the body style was restyled in 81. According to this link 5553 were produced that year. Anyone know the stats of how many were of the old style? I ask because a guy I got parts from said something about it being rare and I should not get rid of it. -
A couple of days ago a co-worker told me of a Brat he has seen sitting and told me where it was. Not wanting to wait I cut my sleep short (on night shift this week) and hit the road. This is what we found, First question is what year is this? I could not get into it to find out. As you can see it has been sitting for quite a while. Long enough for the tires to go and woody vines to grow over to and into the engine compartment. You can see the ends working their way out of the hood. Inspection of the underside, as best as I could manage shows serious amount of cancer on the body but unknown on the important areas. The interior is bleached out and cracked. There is less rust on the upper body. The owner returned my call and we talked a little about it and his asking price. He was told "if" the engine runs that alone could go for around $2000. He said it would not go for less than $500. Now, I do not make alot of money and having bought a running Brat for $200 that is in rough shape but I drove home and back and forth to work with little work done to it. I tend to be quite opinionated on what I think a car is worth and what I would offer if the tables were turned. This has been sitting for a long time, the engine is likely overgrown with vines, so starting it would take alot of work and time and the tires are shot so driving it would be out. At this point I do not know what engine is in it (EA82?) or what could be swapped out with my 81. What would YOU offer for this Brat?
Grinding noise when turning
MaddCelt replied to brysawn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Might want to look into a CV joint. Mine does the same thing. If it is you will want to get it fixed ASAP. Metal on metal is bad and will only get worse. -
Flipped the fuel filter in the engine compartment. Had it on backwards. Located a loose vacuum hose that connected to the top of the carb but I haven't a clue what connected to it. I'm beginning to get irritated with the books I have that have next to nothing on the vacuum system. Even consulted the diagram on the hood and that was about as useful.
Car Stolen... Seattle Area
MaddCelt replied to audio_file's topic in Meet n' Greet. Your USMB Welcome Center
That is great to hear!! We were wondering how that was going. -
Part Identification Needed
Figured out what they are, vacuum switches. -
Glad to see things up and running again. I was beginning to think I was going to have to remove the sticker I just slapped on the window. I found out when there was an email for a reply to What have you done to your Subi lately.
Returning to this thread to post the actual problem. Unbeknown to me, the return line from the canister is gravity fed and since my tank modification put the tank above the canister, it backed up and overflowed. Unfortunately I may not be able to correct that with the current set up. So now I will need to bite the bullet and drop the original tank to see if I can patch it up.
We continue the story were we left off at bypassing the evap canister. A week passes and I am able to drive the Brat again and I was quite happy until I noticed a unpleasant smoke entering through the vents. Got home and noticed a small amount of smoke coming from the engine. Took a look and noticed there was some oil leaking onto the exhaust pipe. Two days later it got bad enough to about fog me out of the car and this morning I located the source/ The valve cover gasket. As my only exp with valve covers came when I helped dad tear apart a 350 in my old Chevelle, this is a bit more unusual for me. What do I need to know, do's and don'ts, and tips to get this repaired?
Ok, this is annoying. Got the starter for the Brat a few weeks ago and two days ago it acts up. Dad said it sounds like a solenoid issue and said to see if it can be replaced. Looked at the local part stores and I don't think I can. He told me how he had used a remote solenoid on his 36' Chevy. Can this be done with a gear reduction starter?
I bypassed the evap Canister after the new one did the same leaking as the old one. Figured out how to do it on the fly (wasn't hard, just plug all 4 lines) Replaced the starter. Cleaned off all the bow hunter decals so I can add my new ones. Figured out how to drop the idle RPMs from 3K to 1.5K Now I need to get under it and patch the floorboard behind the seats. 55gal barrel plastic works wonders.
Same here
Hmmm, possible. My wife said she had a car that the cruise control was a button on the dash. My ignition is pooched and they mounted a toggle switch and a push button to start it and the spot for the start button looks like it was made for it, which could have been for that.
