About Trevor
- Birthday 06/03/1983
Location
Bozeman
Vehicles
I Love My Subaru
Trevor's Achievements
Advanced Member (3/11)
Its been a while since I've said what-up, so I figured I'd show off the new kicks, and say hello! 14" BF AT's will hopefully make for a good summer outdoors!
Well............ Not sure if replacing a torn CV fixed it. Maybe it just wanted to do some offroading, cause I did plenty of that this weekend. Could have just been the HEET with Injector cleaner too Either way its running well again and I am happy. Replaced the O2 sensor just for good measure too. Thanks for the replies! Looks to have been related to dirty injectors or water in the fuel.
I had room for the fans and condenser on my EA82 EJ swap. I used 12" ebay fans. Clearance is a little tight but there is room. Connecting the compressor might be tricky.
So the other day my EJ swap into my wagon started running poorly. I may have gotten on it a little hard, but never exceeded 5k RPM. It idles and starts just fine but hesitates under throttle and is lacking power when cold or warm. There may have been some crud in the gas tank but the issue was not gradually happening, it started right away. Heres what I have tried thus far: Filled the tank - was low Replaced fuel filter Upgraded to XT6 fuel pump Checked for vacuum leaks Installed CEL - Not on Replaced plugs and wires Blew out fuel lines with compressed air Anyone have any ideas? I was planning on checking cam timing next. I do not even know where to start with sensors or how to check them without just replacing. O2, TPS, CTS MAF? Thanks in advance!
Painted my wheels last night, got me some plates and insurance, vacuumed, washed glass, and drove to work today for the first time.
Thanks!
Project has been on hold for a while. But I have made a ton of progress in the last week. Did not want wiring hanging above my feet on this build so I put my ECU in a box in the spare tire well. I picked the components up at lowes for about $30. It should keep water out. Everything is good to go except radiator fans, which are "Out for Delivery" according to UPS Can't wait to do some off roading!!
Made some progress here. It has taken a while, but I found a really clean 91 Loyale with a dead motor and sourced all the parts to repair my EJ. Motor in the bay with the dual range and the lift is in.
Someone turned left in front of me today.
Hyalite Canyon near Bozeman Montana
