Hello everyone! I'm Darren from south GA, and recently purchased a '99 legacy outback with the twin cam 2.5 liter engine/auto trans. The engine 'flutters' for lack of a better term. It almost feels like a cylinder misfire, but it usually isn't that bad. The car has 180,000 miles on it, but appears to have been taken care of fairly well. The CEL was on when I bought the car, and codes showed misfire on 3 of the 4 cylinders. I changed the plugs, reset the light, and it came back on within 100 miles. Same misfire codes. Then put new plug wires on, and reset. I put about 400 miles on it, and the CEL stayed out. The flutter was still there though. (although it did run much better after the plugs and wires.) I put a new fuel filter in, and replaced all 4 injectors. Car runs great above 2000 rpm, but below that, I still have the flutter. The exhaust seemed to be restricted, when comparing the output from the tailpipe with another '99 that a friend has. I pulled the cats off and... well, yeah, I removed a portion of the catalyst brick. Was going to see if this fixed the problem, and if it did, was going to order new cats. Anyway, the car has much better throttle response now, but still has the flutter. Strangely enough, when I reset the CEL light, it seems like the car runs perfectly with no flutter for a few miles. After 'fixing' the cats, I'm getting the CEL again, but this time it is showing a code for catalyst inefficiency. I'm sure this is due to the cats being open. I'm showing .08 volts on the front O2 sensor, and .075 on the rear. I certainly don't mind spending the money to get this thing running right, but I hate to just throw money at it until it works. My wife is a little ticked at me for selling her volvo V70 to purchase this one... guess I should have asked first! I do have a mechanic buddy who says that the problem is a bad inner CV joint, but after putting it in neutral and bringing the engine up to about 1200 rpms, the flutter could be felt. Then he said it has to be a motor mount. I think he's just guessing at this point. Anyway, if anybody has any suggestions, please let me know!
