cohophysh
Everything posted by cohophysh
  1. I found a 2.2 leggo that had been sitting for almost 4 years, just changed the oil, made sure it had radiator fluid and cranked it over, started pretty much right away....and it was left outside for those 4 years and yes I live in a wet climate
  2. I have had 2 90 legacies where the horn wouldn't work, for me it was just the relay. Are you positive you have the right relay cause I know the relay I replaced was behind the fuse box under the dash on the driver's side...and what is a clock spring?
  3. I probably shouldn't have but I adjusted the idle screw, at least that should get me safely home...probably the TPS needs to be replaced
  4. no EGR on 90 but I am pretty sure it has an IAVC, I will check hoses
  5. 90 leg 2.2 5 speed. Car won't idle, was running fine, pulled up to a stop light and it dies, restarted just fine but I had to sit on the throttle to keep it idling...where do I start? MAS, TPS, IACV? other parts to check?? Thanks
  6. ya she has put in the miles...here is another tid bit, it only idles like this once the engine has reached operating temperature.
  7. Ugh.....another problem, this is getting old. 90 leg 2.2 manual 364K miles. so here is the issue, when stopped the car idles between 100rpm-900rpms. Up and down up and down. At one point it did die but started back up. No CEL I have recently replaced Knock sensor, fuel filter, plugs, wires, and PCV. Any thoughts...
  8. actually it was the control unit, replaced with one from the bone yard and voila, all vents are working:clap:
  9. Does anyone have a good link to troubleshooting the A/C in a 90 legacy. The compressor would run but all that came out was hot air.
  10. I hope this is the same for a 90 legacy cause I am going to see what I can find behind the control unit. B
  11. I just bought a knock sensor from ebay for my 90 legacy for 13.00...if you don't mind waiting a couple days, ebay is worth the savings. Autozone had them priced for 45 or so.
  12. I have someone telling me in another forum that the knock sensor shouldn't be moved because it won't sense knock as well, if at all and could cause damage. Any thoughts
  13. 90 leg 2.2, I just replaced the knock sensor, however, I did not put it back where it came. I found a bolt hole up and just towards the firewall that was easy access. So I mounted it there. Seems to me all the knock sensor needed was good contact to the block, so basically it could go anywhere the wire would reach. Is this right? B btw...knock sensor was in bad shape. split housing rusty...yuk
  14. oh bloody hell and f' me running....I replaced all of the plug wires and it is running fine....
  15. thanks for that, I was going to replace the temp sensor as well since it is only a couple bucks
