jerryjer8
Everything posted by jerryjer8
and if it was bypassed then im going to say the egr is not working properly, drive the car 50 miles or so and the check engine will probably come back on, easy way to check and see if egr is working, warm car up, and look under hood, when you rev the motor egr valve should be able to see moving, if it is bypassed and light doesnt come on your still not getting the gas mileage you should be getting and could lead to later problems from the car running to rich or to lean, and with that it could also lead to the problem im at now with my car which is either a bad o2 sensor or bad catylic converter, which is most likely due to the previous owner of the car not getting this problem fixed to begin with $79 at any subaru dealer, and no tools required to fix in less then 2 minutes
i have a 96 outback legacy with 2.5L. ive been getting a p0420 code lately, about a month ago i had to change the back pressure transducer going into the egr, and since then i get a p0420 bank 1, and a second code for the same exact thing that says pending, i recently bought this car a few months ago so i dont know how long the egr wasnt working correctly, my thinking is telling me that if it was running richer becuase the egr was not working correctly, then maybe it gunked up the front o2? does anyone else believe my thinking is correct, i warmed the car up earlier and got it good and hot went to pull the front o2 and look at it and it is very very tight, while the back o2 felt it was very easy to come loose, i did not pull either out to look at but im thinking that maybe the front o2 is stuck open and not allowing it to come out easily. should i just start by buying a new o2 for the front and start there. off my code reader i get p0420 1 of 2 catalyst efficiency below threshold (bank 1) p0420 2 of 2 pending catalyst efficiency below threshold (bank 1)
yeah someone else mentioned the fluid pump, and the more i listen to it, that is what it seems to be, nothing else is wrong with the tranny drives and shifts great, now the next question is how hard is this to change? and if the pump is shot am i better off to get a new transmission. ive got a quote off the internet for a warrantyed complete tranny for 695 and then i can drop and put it in myself, im calling a shop on monday to get a quote to fix the problem, but im wondering if the pump is going bad how much damage has this created that isnt known yet? and if i take it to a shop they may pull the tranny and tell me the pump killed the rest of the tranny and that they will need to replace it, and that leads to excessive labor and parts that i could end up doing myself, ill pull and swap a tranny but im not going to get into pulling the tranny apart and trying to fix things inside it.
recently bought a 96 legacy outback, have a noise coming from transmission, it runs and shifts fine, the more i read and get advice it sounds like it will end up being transmission fluid pump, question i have is i dont know when the last time the fluid and filter was changed, could it be possible that im getting the noise because its old and needs to be cleaned out? and maybe its getting clogged up? (im new to not only subarus but also automatic transmissions) or is it once those pumps are making a noise that means they are shot and need to be changed? just wondering which way i should go, thinking of taking it out to have fluid and filter changed tomorrow morning but if it definetly wont help i will just save that money and wait till monday to take it to a trans specialist and have it pulled and replaced
96 legacy outback automatic, where is the transmission fluid pump? is it accessible through the pan? or do i need to pull out the entire transmission to access it? i ask because i have a noise coming from transmission somewhere, it almost sounds like a power steering pump does when it goes bad, i am starting to think this may be the problem, it makes a whining bearing sound no matter it being in park reverse neutral or drive,
i have a 96 legacy outback 2.5L dohc ej25d with auto trans, where can i find a diagram or schematic breakdown of all parts inside, mostly concerned with seeing what is inside the bell houseing, have a noise coming from something inside between engine block and main body of transmission, almost sounds like there is a bad bearing or something inside, makes a high pitch whining sound, i recently bought the car dirt cheep knowing it had a few issues, but the body is in superb condition so i knew it would take a little work to end up with something very nice. when i got the car i noticed it was missing a rubber plug up in the top of the bell housing, i think it was called the timing hole plug, i dont know how long it has been missing but my thinking is it had left the flywheel and what ever else is inside exposed by not having the cover on it, so who knows what has gotten inside and possible ruined what ever bearing there may be in there, any ideas or a place to get a diagram of what is actually inside would be appreciated.
if anyone could give me a few suggestions as to this problem i would be much appreciated, i am fairly mechanically inclinded but this is my first subaru, and there engines are nothing to what i have ever owned in the past. i recently picked up a 96 legacy outback with a 2.5L ej25d automatic, i got it really cheap for a fixer upper, body is in absolutly great shape and i felt i could be up to the challenge of learning a new vehicle, i have a noise coming from somewhere between the motor and the transmission. it kind of sounds similar to a sound ive heard on other vehicles when a pulley bearing or something is going, its like a high pitch whining, the sound comes and goes, and varies with engine rpm, sound starts right when i start the car, and seems to cut in and out at random times from there, i almost thought that maybe it could of been the starter because it seems to come right from that vicinity of the motor, and the sounds is like maybe it could be small electricall motor spining, my first thinking was that maybe the starter wasnt fully disengaging from the timing wheel completly, but then my second thought was that even if it wasnt that when the sound cuts out it would probably really clan when the sound starts back up and it doesnt, so i dont know does anyone know if this could be a possibility? or should i maybe be looking around the driveplate or flywheel or torque converter? but then again this sound is present whether im in park reverse neutral or drive, the sound can come and go as i sit still and rev the motor as well as while im driving. im pretty inexperienced with auto transmissions to, ive always had a manual, but my general thinking is it really shouldnt be any of these because when its in neutral and park nothing is engaged. could this be the starter somehow? or should i be ready to pull this in the garage and drop the transmission and start looking around? any advise before i have to pull this inside would be wonderful. thankyou
