Travisthedrumer
About Travisthedrumer
- Birthday 09/22/1989
Contact Methods
AIM
punkdevicegone
Yahoo
travisthedrummer
Location
Nashville
Interests
Rally, Road course race
Occupation
Construction
Vehicles
1988 DL Wagon, 88 Celica
Travisthedrumer's Achievements
Advanced Member (3/11)
0
Sorry for the delay. My computer has been down for the last two weeks and is still in the shop. Using one at the local library.
John
Travis' 88 Wagon FIX "Build"
Travisthedrumer replied to Travisthedrumer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Or not. Was just informed I HAVE to sell it. It's a non running car, and according to the lease, I can't have it... :[ So. Check the part out/ for sale forums. I loved that car. I actually cried when I crashed it... -
So, I wrecked my Roo today. I rear ended a semi. Car won't spark, but it will turn over. I'm keeping the Roo. I'm gonna try and get it looking nice again. :] I'll be around. -
Quater glass question
That was well put. Im not sure what exactly I was thinking. The Celica fell through. Now im hunting down new heads, because my exhaust needs to be re drilled, and no one will do it. People in Nashville are scared of aluminum. Pansies. -
OK, Let's Nail Down This PURGE SOLENOID Thing
Travisthedrumer replied to Tank's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That was awesome. -
So I pulled codes finally. Thank you Grossgary for the link to the XTforum, and thank you GLoyale for the tip about the "no stored codes" Mine did the same thing, and thats how I got these Codes. 31 Throttle sensor or circuit 32 Oxygen sensor or circuit 34 EGR solenoid or circuit 35 Purge control solenoid or circuit Whats a Purge control solenoid, and how do I fix 31? O2 sensor will get changed, and the EGR will get a 33 Ohm, 5 Watt resistor, thank you GD. Your not THAT much of an rump roast. But seriously. Whats purge control? Exhuast? Cause mines still super messed up. Thanks guys, going to get some parts today hopefully. EDIT: Wow. If its the throttle POSITION sensor, Junkyard special. Duralast/Throttle Position Sensor Part Number: TPS4032 Price: $399.99 Thats more than I paid for my car. That's more than 4 new tires cost me, plus a tow. On a happy note, the Oxygen sensor is 20 bucks. -
Wow. Been awhile. Alright. Got a new car, and 88 celica, and thanks to the forums, I've decided to keep my soob. Question #1- Application of brakes. what will fit my DL? disc on front, drums on rear. I tried Using the search function, but it didn't want to work for me. It kept telling me I needed to wait, then it would timeout. I need a new cailper, and a WHOLE new back drum system. backing plate, everything. I actually have a steady income now. the transmission will have to wait until it explodes, and when it does, it's getting an automatic again. Question #2- how hard is it to adjust timing, and replace a belt without pulling the motor? If someone could link the post, that would be much appreciated. Question #3- I put 8000 miles on my car in less than 2 weeks. Also, got a wally world oil change. -.- Any suggestions as what i should do as far as fluids, belts, hoses, anything. This is my work car, so I can't put it out of Commission for more than a weekend. So, to answer the first question, anyone have some brake parts? I need a front passenger caliber, and a rear pass. drum. everything melted inside it, so i don't know if anything is reusable as far as the backing plate goes. -
Ah. makes sense now. Well, molded rubber, but unfortunately, I'm gonna have to get rid of my soob, and either find another one, or go with a Handa. It's been a great car, but the previous owner just didn't really take care of it. He did a rebuild on it less than 20K ago and it drips oil out the driver's side heads. The trans has never been touched, and it had 22 year old fuel filter, plug wires, and he re-used all the gasket's apparently. I tried to fix my exhaust problem today, but the bolts had been taken out of the block once already, so they wont seal right anymore. It's just getting to a point where the money going into it is way too much. -
Haha, but I don't need Legacy glass. I need DL glass. Mines broke. I covered it with duct tape. :] -
Sooby, did you just offer me glass I can't use? I almost said yes, then I read it again. haha. Slickness with a quickness. -
Can I use a Legacy's quarter glass for my 88 DL? There's 4 in pull-a-part. a 90, a 91, a 94, and a 92. Can I use any of these?
okay, so i picked this up while working at Vavoline. Dawn. Yes, Dawn, this dish soap. That stuff is amazing at getting grease off of you. If you have grease all over you, oil, trans fluid, whatever, take a shower, bring some dawn. shower with it, then use your body wash of choice. I prefer Axe or Old Spice... P-p-p-p-p-p-POWER! BUILDING KICK! EXPLOSIOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON! Sorry, side tracked.... ANYWAY. Yeah, Dawn works wonders. I've washed my hair with it too, it pulls it right out, then just run some conditioner through it, or you hair will feel like a cacti. :] just my two cents.
Yeah. I forgot to mention what ever happened with that. I tore my dash apart, found the wire, and put it on my horn switch. Pressed the horn, BAM. Instant wire meltage to my hand, jeans, dash, and both connections... oh yeah, plus it was on fire in one spot. I didn't even BEGIN to think about using 10ga, or even 12 ga... nope, grabbed the first thing I found, partly because I was kinda irked and wanted something to take my mind of stuff... Yeah, It was 20ga. it was melted and firey. That ended any and all thoughts about running my starter to a switch. I did however take my stock soob to an ORV Park about 3 weeks ago, before my car started to do bad things. And told some guys in a truck... "Silly boys, Cars are for mudding too." They thought it was hilarious. Till I powered through a hole that his truck got stuck in. Then he thought it was bad rump roast, and wanted to know where he could get one. They also ended up pulling me out of a sinkhole. so glad for tow hooks on front. im also glad my exhaust is broke at the motor, cause it was buried at the back end. -
Theres a write up on a 5spd from 3at on an ea81. will it be the same for an ea82? Im wondering if i will need the same parts, such as those plates that bolt it up to the crossmember. -
Well, instead of checking the timing, because I don't have an engine hoist, I decided to look for a job. I drove to Manhattan, which is about 1.5 hours from here. My 3AT decided to blow its fluids all over the road... as im doing 70. I realized about the time it whine on deaccel. I pull over, and huh. I'm dry. It needed something, so I threw trans-x in it. It held till I could get to the closest gas station, 9 miles away. Welcome to BFE KS, where Dextron III costs 1.89 for 2. :] I got it home, to find out that my Dextron and what is left of the gear oil in the torque converter might congeal, because ones a synthetic, and one is... not i guess.. I dont remember how he explained it. But yeah, If there is no validity to this statement what-so-ever, I'm gonna go ahead with the manual trans swap. Thank you mdjdc. If their is validity to it... well, my brother's smarter than I thought he was, and I'm still gonna Man trans it out. I want to thank all you guys that have went to sold me parts, then I couldn't get them. I wanted that AWD trans, but, I couldn't afford it anymore. I wanted that passenger mirror, but, now I really can't afford it. i'm hoping that the trans will bolt up, not questions asked. that would be awesome. I'm also thinking that my subaru is on its last legs. I really need to get a second daily, and tear that one down, and fix it right... not rely on lucas and sea foam. Haha, in unrelated non-subaru news, I found an abandoned toyota supra, just like my old one... only turbo. So, I might get that, and make that into my daily. It looked good, and I've already got a motor and 5 speed trans if that one is done. Well, here's to hopes and dreams
