TommyH
About TommyH
  • Birthday 01/01/1979
  • Location
    Suomi Finland perkele!
  • Occupation
    Machinist
  • Vehicles
    Subaru Harvester
TommyH's Achievements
Member
Member (2/11)
0
  1. Subaru Domingo with Yamaha engine Buildup tread translated: http://translate.google.com/translate?sl=fi&tl=en&js=n&prev=_t&hl=fi&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fforums.offipalsta.com%2Fshowthread.php%3Ft%3D66233%26page%3D4
  2. TommyH
    plow car ?
    It's a 4wd 1,2 Liter Sumo (http://en.wikipedia.org/wiki/Subaru_Sumo) . No problem with 12" of fresh snow. And its nimble as hell. That wheelchair lift sounds good but adds too much weight to front axle. I'm just going to get better winch to replace that old chinese no-brand thing.
  3. TommyH
    plow car ?
    Here is our Plow Car It has worked well for 2 winters =) Only weak link seems to be the puny Atv winch that lifts the blade up.
  4. There is a 20 liter fuel tank out of a Ski-Doo Nordic behind the passenger seat strapped down with some gargo straps. Mb 190E tank would be alot better. Its bigger and if i remember correctly it would fit between rear shock towers.
  5. Hmm.... How fast is too fast? Flapper is made from 3mm steel (0,0762") so I don't think that i'm ever going to drive that thing that it bents with wind force.
  6. Just get lots of long sawsaw blades zzz ...and strengthen the roof before cutting.
  7. Front pipe is stock followed by selfmade y-pipe with 110degree bend and a 16" long 2,25" straight trough muffler with somekind of a flame killer inside. Mufflers outer shell seems to be about 5".
  8. Huge update Tons of more power
  9. Nothing new really... Gearing was way off with mudzillas so i bought set of used 235/75-15 Bfg At's. Planning to try them out this weekend with hopefully not so much smoke from clutch ...might have to cut/regroove tires for better offroad/mud traction.
  10. They are well worn Maxxis Mudzilla LT 33x13.50-15 I might have to get rid of the back doors Front wheels are rubbing on lower spring plate. 2" spacers will fix that problem...
  11. Hood didn't leave a mark on the windshield. Fortunately hood is so flimsy with that hole in the middle There is rubber hood straps trying to keep hood closed. Next time i might remember to hook them properly ...btw the windshield is a nice accessory driving around at -25 degrees Celsius (-13 degrees Fahrenheit)
  12. Some winter fun with Harvester
  13. Thanks Janis. Leones are gettig rare in finland, good ones are very very rare... You can check out availability yourself at http://www.nettiauto.com/subaru/leone/
  14. More fun with Harvester
