tricked919
About tricked919
- Birthday 09/12/1976
Location
WNC
Vehicles
I Love My Subaru
tricked919's Achievements
Advanced Member (3/11)
0
When I did the swap, I R&R'd plugs, wires, coil, belts, and also a TPS because of an immediate TPS code. I put all new vac lines as well - every inch. I'm getting about 24mpg on a long road trip - and 20-21 in town. We have an '03 Impreza OB that gets about the same. (Not NEARLY as rich) Yes, its run rich since the first crank. I absolutely notice its way worse at cold start. The rough idle was actually a bigger concern that I linked with the "rich" condition - maybe? Since the swap, the only code I ever got was an EGR, but that was because the little metal tube from the TB to the EGR modulator clogged. I never have replaced the upstream sensor ...AND I'm also running the EJ25 intake with MAF. I have the EJ22 intake, but its in awful condition. Could that be it?? ...I just would have sworn that this level of "richness" would have thrown a code at some point. There are mornings that this thing smells like its spitting raw fuel out the pipe. I was just curious if there was anything I could do to manually fool it into leaning.
so its been WELL over a year and about 15K since I replaced my toasted EJ25 with a 96 EJ22. I've been CEL free with no shortcuts on anything, but the motor has been running rich ...and we get a bit of a rough idle when warm. It also feels WAY underpowered compared to the EJ25 - that's understandable from it being a weaker motor. Someone recommended finding an EJ22 auto/EGR computer and that would have the proper parameters programmed into it - right now I have an EJ25 ECM running the show. On all the swap homework I did beforehand, nobody aver said anything about grabbing the ECM... Exhaust just smells awful and I don't want an 0420 because of a bad cat if I can help it. Thoughts??
absolutely... many have done it (self included). The EJ22 is a pretty straight forward plug-n-play. Do a search - there's a bunch of caveats. Be sure that the EJ22 you can get has the Y-pipe - that's imperative. Here's another proposition... I have a pair of heads from a 98 EJ25 that are in excellent condition that will serve as another solution.
I got baptized by fire last summer when I bought a 98 OBW that had an impressive list of recent repairs (incl. new HG's). Long story short, despite the quality of repair, toasted main bearings snuck up about 500 miles after I got the keys. Rather than get another EJ25, I opted for the 2.2 swap. I did it myself and low and behold, I fell in love with the car and its new simplicity and the reliability reputation of the EJ22 ...its since been all over the country and the car is doing awesome. SO... I'm in the market for another Subie to add to the family. I'm thinking a bit newer this go around. For some reason, I'm leaning towards an '02-ish Forester or Impreza (non-WRX). I'm curious if any of the overheat issues ...blown head gaskets... are much of a problem outside of the infamous early Outbacks? Thanks ...and I still have a pair of 98 EJ22 heads in AWESOME condition.
Hey guys ... long time! I've now put close to 5K on my '98 OBW since swapping the 2.5 with a '96 2.2 I used a 96 motor with EGR. The EGR is definitely toast but the car has been running great. I've had a CEL on since the swap regarding this. I'm also now getting a code for TPS. Two questions... 1.) will running with a bad EGR hurt anything? 2.) I'm assuming that the TPS is in the throttle body. Can I swap the TB off my old EJ25 with the EJ22 TB? They look identical. Is there another easier fix? The car runs great... mpg is mid 20's. The only issue I notice is that the exhaust smells a little rich. Possibly related to either? All the miles since the swap have been local, so I haven't had the urgency to mess with it. I'm getting ready to put about 2K on it next week and if it needs to be fixed, I will. Thanks guys.
How did your 2.5/2.2 swap go? I've got the 2.2 sitting in my garage, and I just got done cleaning it up and installing a new timing belt etc. I'll be pulling the OBW in tomorrow morning to get started on it. Can you give any advice about things I should be looking for?
Yeah, I'm tempted to just pull the heads and sell them. Are we talking $50 or $350 ?? I looked all over and there's nobody selling an EJ25 with just a bad bottom end. Most of them have toasted heads, amongst other things. yes they were machined. The guy who put the heads back together is about as good as it gets.
So my EJ25 from my 97 OBW has been sitting in my garage now for over a month since the swap. I swore I was going to tear it down and rebuild it but I don't have time. I'm trying to post it on CL but I have new clue what to ask for it. The motor blew a headgasket at 148K. The repair was done very well (valves shimmed perfectly) and the car drove great. Apparently when the motor overheated it did a number on the main bearings because roughly 1000 miles after the HG repair, the motor started knocking. Before it got too bad, I pulled it and swapped an EJ22 motor in the car. During the swap, there were some parts that I used off this EJ25 that were bad on the 22 (I used an idler pulley, fuel psi regulator, and a couple vacuum lines. For the most part, this is a complete motor that is great for parts or a rebuild. This would be a great motor for someone who needs heads for an EJ25 - the heads are perfect. The motor is probably the cleanest motor out of a 97 car that 's available (only it knocks :-\ ) ...ohhh and I live in western NC ...land of a million subarus. ideas?
I had the absolute exact same problem ...only my knock started about 1000 miles after the headgaskets were done. Apparently the heat got to the mains. I did a EJ22 swap from a 95 lego sedan. I had never pulled a motor in my life, let alone swapped one with a different motor. I can turn a wrench but this was way beyond any task I'd taken on previously. The 22 I found was a mess. I spent a couple hours every night for a week cleaning it and changing all the gaskets, seals and a new timing belt. I also took off a lot of the newer parts I had on my 25. On a friday night I prepped the 25 to come out - on saturday morning I went and rented a hoist and by roughly 1pm I had an EJ22 in my 97 Outback and running great. I had a few minor issues with vacuum lines. There was vac solenoid for the fuel evap system that was on my 25 and not on the 22 and I had to find a way to bypass it. The one word of advice I have.... MAKE SURE YOU GET THE DOWNPIPE!!! The EJ22 head is a single port exhaust. The 25 has a dual-port. I got my EJ22 from a junkyard and I made it crystal clear I needed the Y-downpipe. They told me they couldn't sell it because there was a catalytic converter in it. There is no converter in it - that's BS. So anyway, they pulled the motor the day I was to pick it up and apparently the tech ignored the orders and cut off the pipe because he couldn't break the studs off. They spent a week trying to find me a single port Y-pipe for an EJ22. So make sure the EJ22 you find has a Y-pipe and do whatever you have to do to get it.
I put a billet flywheel and a carbon clutch in my SC'd 350Z and I DEEPLY regret it. It made the car's throttle and rev response as fast as a motorcycle ... with a quick throttle blip, it would wind up to 6K and drop to idle in less than a second. The performance gains were nice ...however they weren't worth the poor drivability and NOISE. I did my homework after and found that its common for these set-ups to cause a lot of chatter. I had a VERY difficult time selling the car because everyone who listened to it idle thought the car needed a valve job or I dropped a coffee can full of beans in the bell-housing. In my case, the clutch and flywheel was hardly more expensive than OEM parts. It was a no-brainer at the time. The car was still INSANELY fast w/o the set-up - I would have rather had it sound good and rev like a normal car. Just my opinion. I think they are really overrated
Thanks again guys ...you were correct again. Yesterday afternoon the lifter noise went away !!! The motor still has a heavy piston slap right at cold start, but sounds like a million bucks a second or two after. Once its warm, it runs even better. It has some spontaneous vibrations and rpm flux at idle, but we're talking about a 13yr old car with a 15yr old motor. It has all new plugsm wires and a clean throttle body. If anyone can suggest anything, please do. I'm leaking a little oil from the drain plug, but that was expected. I used the original crush-ring because I planned on changing the oil in a week or so. If keeping a qt of tranny fluid in the motor all the time is OK, I'd like to keep doing that. It doesn't thin out the viscosity too much? I had a CEL come on last night and when we restarted it to head home, it was off. I have a vac line under the manifold that needs to be replaced. I'm going to eventually re-do all of them.
