So I purchased A 90 Loyale A few months ago and have been fixing what I can when I can. When I got the car the oil pressure gauge didn't' work, needle is below zero. When you turn on the ignition switch the guage goes up to 85 then goes to zero. Start the car and the gauge goes way below zero. So I ordered a new oil pressure switch with gauge from rock auto ( Beck/Arnley part # 2011341 ) great part is it was only $3.64 (same part at advance is $50+) So I noticed the oil pressure switch I'm purchasing looks different than the current one installed on my Loyale. I assumed that they were the same diameter and thread and would fit in the same location. Well the part came today.
[/img]
Now I see that this part goes in a different port, which has what appears to be the factory plug. So I took out the plug, installed the new switch and oil pressure now works kinda. Turn on the ignition switch gauge does nothing (maybe this is how it is supposed to be?) Start the car, gauge is well below zero. Raise the rpms or drive, the highest oil pressure I get is dead on zero. I haven't removed the old switch
[/img]
because I don't have a plug for that port. I assume that the old switch is oil pressure switch with light. At least thats what I have figured out by looking at parts online at multiple websites. Now Assuming I have the correct switch NOW:confused: How do I get the gauge to work properly? Does anyone know the ohm values for the sending unit? Can I raise the resistance with a resistor to make the gauge work within the proper values? How can I tell if the motor is not original?
I know thats alots questions for such a simple thing but I really would like my oil pressure gauge to work especially since I have one. I hate dummy lights.
Thanks for any and all help in this issue.
