5
Everything posted by Subruise
Ascending to hatchdom......and fun with little issues
Subruise replied to Subruise's topic in Members Rides
well......im sellin it. i fell in love with this brat i got in payment for an engine build. i had planned on selling the brat but id really rather keep it weber needs a lil more tuning. -
relays. Jezsek has a great write up. saved me
This carb was on the engine when I installed it. its from a non feedback 85 BRAT. I would assume that if it ran there it would run here (I saw a video too). choke is getting .6v. my battery was low, which is a similar sypmtom to Skylar's maxima alt swap. would the existence/influence of the california ecu mess anything up? -
ya, choke is plugged in, will check other stuff as well. I have a 89 mercedes to drive until it sells, so i can take my time -
caliper got replaced again. got the correct correct one this time. dropped in the new webered engine today. wondering if my feedback model car is giving it fits for some reason. I was unable to use the harness supplied with the engine (85 brat) in my 87 hatchy, so i used mine. It idles high and dies. also has a 65 secondary jet, which Ive been told is too big. throttle response is slow to die off (i.e blip throttle and it swings up before coming back down) I saw a viseo of this engine and this exhaust running in the PO's BRAT and it seemed fine then...what gives? -
Ive bent skidplates, never tried stacking them. and my 91 loyale came w one, so maybe it was an option?
- 17 replies
- cruise control
- button
- (and 8 more)
My friend has a 96 lego wagon AT, with the following symptoms. NSS was replaced once already, and I have yet to see the car. This cant be the first time this has happened. searching was unfruitful so Im trying the direct approach: Check engine light flashing, says it's the neutral safety switch (which is replaced with a new one) but car randomly dies and it will fire back up and die again a few miles down the road
loyale died high speeds tips needed quick!
Subruise replied to joe5's topic in Old Gen.: 80's GL/DL/XT/Loyales...
one must find the perfect length screwdriver -
its either that or the screw that holds the rotor to the disty shaft. either way, same procedure -
you can change cams w/o doin hg's btw
http://www.harborfreight.com/555-piece-cotter-pin-storehouse-67558.html =)
unfortunately the rebuilt caliper was a drivers side with a passenger side ebrake lever. bummer. I have to get to work tomorrow so ill be attempting an upside down caliper install .... I might have some used ones coming in from portland maybe. -
Help, Brat, can I swap the loyal front end over?
Subruise replied to dec0y13's topic in Subaru Retrofitting
ill get it fingerd -
pretty lame i know, but i havent been able to break em loose.... -
update by absolutely no demand: bad news first: shes been down for a week or so due to a pooped passenger side caliper (front, no rear discs yet). I have one on the way now. Good news: i got a weber for it today....which came with a nice and clean, refurbed ea81 hydro motor stuck to the bottom of it. now itll haul the mail. who needs brakes? they only slow ya down. Ill actually take pics this time so everyone can see what happens when your engine leaks oil.. from between the block halves on top of it. no 5 speed yet, i traded it off for a ea82 for the wheeler. Im thinkin single range 5 speed would be perfect for this car. -
yup, youre good. if you can find a forester s in the junkyard, swipe the oil cooler too
hi Kevin, google ej22 swap. welcome to the board
hello old thread. I just tried to swap gen3 knuckles onto my gen 2 (87) hatchy, no worky. The tie rod ends are too large in diameter and dont seat. I put it together anyway and we are in a no go, floppy wheel situation. Whats the secret? I know you can put just the knuckles on (but i dont know how)....people claim to have succeeded. -
ill get ya a 5spd dr and figure out how to ship it. lmk when youre ready.
EA71 & cylinder head aligner
Subruise replied to impostor's topic in Historic Subaru Forum: 50's thru 70's
ypull be fine. drain it beforehand of all fluids. it is possible to change heads in car, but ive never gone that way -
thanks sapper, im running just the head unit currently, no tape player. I did use an aftermarket stereo today with another speaker and ive got tunes. its pretty distorted so maybe ill fiddle with grounding locally. if i press on the speaker its clearer and louder.
ill be camping in it this weekend. perhaps next week, Ski. I know the speakers are good, bit the radio might be cooked. it looks a lil rough. it lights up and tunes to stations which i can hear, but barely. I have to go hand crank my portable am/fm now
Im trying to install a radio from an 88 wagon into my 87 (but gen 2..like a brat) hatchy. Why? because thats what i have and so on.. Ive gotten so far as to get the radio to turn on (blue wire radio to blue/yellow hatchy). and even tune to a station, I hooked a speaker up to the green/ greenblack wires and can hear the sounds but its barely audible. Ive messed with all the settings on the radio and now Im stuck. It would be nice to be able to listen to NPR on the weekends while driving around without having to recharge a portable radio. Someone help me before I end up catching it on fire
if you get parts from an awd make sure to get the outer axle stubs so you can use them to hold your stuff together. might have to het the trailing arms too. easier to get fwd stuff, but im not sure xt6s came in fwd flavor
