5
Everything posted by Subruise
i made the comparison between the two to illustrate that just because a product makes a surface look better for a short time, doesnt mean its doing good things. Just trying to draw a parallel. basically you need to use more and more of it while it makes things brittle and wear out. Perhaps i should have compared "tire wet" which is silicone and bad for your tires, but hey, we all gotta bling right?
good deal on the BRAT, the jumpseats arent worth 400 but still a good deal. i paid less than half that for my 78, with jumpseats. mine has a ea81 but doesnt run yet. im sure fixing your ea71 would be cheaper and easier than swapping in the ea81, im not sure itll bolt to the trans bellhousing. hg jobs are fun, get good parts and take your time
pulling the engine is super easy. I just sold a motor to a member here and he pulled his motor by hand with the help of his sister and a passerby. where there is a will, there is a way. get on youtube, search MilesFox or "the art of subaru maintenance". Miles makes great videos and its quicker than having to wait for responses with typical q's. grab a sixer of that excuse for beer you guys have down there and watch some vids about your ea82. first time motor pull only takes a few hours. fixing/cleaning your engine/engine bay (im sure its horrible if you leak lots of oil) will be LOADS easier. less up and down to the floor is nice in the long run. do it right, do it once.
soap and water. maybe windex or other glass cleaner. once you use "keep it shiny and moist" spray/wipes or any conditioner, it only begets the need for more. your plastics will look good until the product wears off, thats where the degradation and erosion occurs and helps make the plastic more brittle. Honestly, bacon grease would work really well and smell good. a good substitute is finger oil, which takes time.
the skagit river; its what makes a subaru, a submarine
rear main only if it shows weepage. personally ive never had a problem, but it seams folks install these wrong with regularity. might as well rip the cam cases off and install a new o ring (dealer only part) on each one.
replace all of the parts Miles just mentioned. replace both struts though. ive been where you are. put in "new" (read: straight) stuff and then get it aligned, probably wanna find an alignment shop who has done soobs before. i also have a thread in the usrm that can lead you to aligning it yourself
http://www.youtube.com/watch?v=5nmOMo4OPi4 RUSH TAPES! The force is strong with this one.
hey Twitch, what did Ken say about the ea71 pistons v the ea82 ones? Im piling up stuff to build a spfi high, but not too high cp ea81 this summer. Im glad youve got another ride to play with, I like youre threads. cheers, RV
clock replacement/dash removal ques.
Subruise replied to Dee2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes the resistor burns out. its a blue 2w resistor iirc. theres a thread in the usrm i think -
dude. its totally possible. I have a 91, same exact deal (except i have auto belts and you might not). Next time, take the clock out and jiggle it around, see those wires moving? the plugs up there. glad you got it sorted out tho. btw what do you mean "unrepairable" -
break them off, throw them away, you dont need em. i carry an extra set of belts, a 12mm deepsocket, and a 22mm. ive changed a timing belt on the freeway in 20 minutes. cheers
open your glovebox, push in the corners and itll open all the way down. youll see the connector. -
Ea71 with HLAS and points?
Subruise replied to mikaleda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
umm we had hlas before 85. Even if by not much. (84 was the cross over for ea81s) -
My daughter is about to turn 4 and can already identify a soob purely on the sound. well done sir.
looks kinda like an SJR to me, might not be tho
full of info that can be found by using the keyboard and not creating yet another useless crappy thread that is all over the place. who cares about 13" tires no one can buy. this thread began as a redundant question and has morphed beyond that scope. there are tons of threads, diagrams, anecdotes, and wastes of time if you LOOK for them. I believe the gruff responses can be related to how long a person has been on here, and how many times we all have to see this question. I think making new threads should by more difficult than searching. then maybe people would do it more. Where is the gong button? I've got a mallet at the ready.....
wedge the wheels? the bolt wont back out and fall off as long as you disconnect the coil wire. only bump it for a second. itll be broke loose. the important thing is to brace the breaker bar in such a way as to not let it swing at all when you crank it. ive done this to subarus dozens of times and the only damage was when i forgot to pull the punch out (and that was assembly, not dis assembly) you retain control if the coil cant fire the plugs
please use the search function. short answer, no. welcome to the board.
