5
Everything posted by Subruise
you sir,have a lot of cars
this is good idea comrade
Subie L. Jackson build thread
Subruise replied to subieman666's topic in Old Gen.: 80's GL/DL/XT/Loyales...
good luck buddy.... -
you guys should come run down here once in awhile. the 5 hour round trip on a wheeling day is what scares me off. stuff comes in waves. right now the tide may be out but itll return....
i see no repairs on this thing. just a need for them. gitcher bunghole up here and check it out/drink beers also no dents in tailgate, just rust.
somebody tried breaking in to my soob!
Subruise replied to subi dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hey! at least somebody got it... -
Making a Polyurethene Bush or Bushing
Subruise replied to NickNakorn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
good write up- 14 replies
- 1
- Suspension
- damper
(and 8 more)
Tagged with:
that sucks dude! move back to tacoma -
Help! EA82 Intake Manifold/Busted Bolts
Subruise replied to EasyDoesIt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1) mark the center of the broken bolt. 2) lubricate with pb blaster or what have you. 3) drill a small pilot hole as deep as you can. 4) lubricate and step up drillbit size. 5) repeat as necassary eventually you will have removed enough material from the bolt that it no longer holds tension. ive had luck with this method. every once in a while reverse the drill and see if you can get it to spin out. Ill add that easy outs suck IMO, they tend to make things messier and less precise. they also have a habit of breaking off. if you screw up and bugger the threads in the heads just re-tap the holes. hth, RV -
generally, make a post in the thread youd like moved asking the "mods" to move it to the appropriate forum. sounds like a fun project. welcome
- 6 replies
- warthoghalo
- halo
(and 2 more)
Tagged with:
What would make a D/R 5 spd pop into 4wd when turning left??? Im postulating the lift has something to do with it. What say ye folks?
same symptoms as half the hondas have around here
A different kind of performance question
Subruise replied to chaz345's topic in NA Fuel Injection Engine Tech
heres some decent reading I came across http://ecomodder.com/forum/ -
knocks while driving in straight line
Subruise replied to ontherun987's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the lack of change you felt when applying the brakes could be attributed to the brakes not being attached to the wheel cylinder and thus, not moving -
seriously somebody knows where this car came from........theres just too much reverse engineered alien technology under the hood for them to not be using the same cookbook (USMB). Come forth phantom....
make that a full functioning, correctly installed fake wrx scoop
the throttle body hoseclamp is tight on the plenum right?
Gen 2 Rocker/Doorjamb nuances
Subruise replied to Subruise's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Im feeling optimistic about success here, my insouciance usually gets me through if I ask enough questions pertaining to the ramifications of the task at hand. School is over rated. I went through the whole thing "wasting" my time on things I felt I should be learning. So far it worked ok, however it would have been nice to have a curriculum based around my interests. But then again, if a frog had wings he wouldnt bump his rump roast when he hopped right? -
YAAAY nomenclature! impressive vernacular and vocabulary Miles. And woohoo for parts, one of these days. thanks -
Can I cut the rockers and jambs out of any gen 2 and use them on my 84 BRAT? side question, do we always capitalize BRAT or is that bad form?
