5
Everything posted by Subruise
oh, no, i think hes accepted the fact that the enlgish litereal definition of "cherry blossom" is in fact pink...
Identifying LSD rear end?
Subruise replied to Dawsonator's topic in Old Gen.: 80's GL/DL/XT/Loyales...
probably, i see lots of clean tags in the junkyard. ive also been known to check the tags of cars awaiting the yard, sometimes they leave em in the parking lot whilst doing paperwork. the clutch type lsd is the black lotus of diff chunks for these guys......rare and sought after mercilessly. and when they do change hands, it aint cheap. -
ya, spfi stuff works as far as ive heard, havent done it yet. i too suck with wire
ive got a few, ill dig around tonight. i made sure to piss the woman off real good yesterday, that way i get to wrench today
shall i pack u a used one with yer stuff? ive at least got parts
there ya go! maybe someone with more skills than just using a keyboard:clap:
you will need to install fuel lines that(and pump) are rated for the capacity needed for an ej
at least now you can get some sleep eh? goodies goin out this week minus the door pad that i have yet to procure
I've got a brain teaser for you.
Subruise replied to Steve W.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
my oil pressure monitoring system: if it aint tickin, its got oil pressure. -
did you get your harness?? do you need just the engine harness or everything (ecu etc) my first car was a 81 glf coupe ea81 2wd 5sp same color as yours. nice work so far
so yesterday one of my recently installed struts decided to seporate from anything bolted to the knuckle and wipe out my ps axle, and dern near the tire as well with the spring perch. stupid used limey built struts......( i dont hate limeys but cmon, who spot welds things when you should lay a bead on that puppy like ALL my other ones) im just lucky it was at the end of the day and at less than 25 mph
i got a set of ea81 headgaskets somewhat by mistake, ill put em in your box. that said i pray you dont have to use em. must suck to be all rusty, we just dismantled a 89 glw in under 8 hrs, mostly with my craftsman 19.2v cordless impact. car was straight too, you should be pissed:brow:
EA82 sub-model question
Subruise replied to glcoupeguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the distys are different depending on 4wd vs 2wd, not ecu..those should be the same enough. use your old disty would be my advice, however there are more experienced folks on here -
i dunno, i suppose ill add it to the checklist. it would be nice to have it be easier. my spare stuff has 90k less on it.
ive only done a couple TOBs but ya, i grease all moving parts in there.
you may want to take the few minutes to check the back of the fork.......the one i just put in a car looked great on the outside but you could see the cracks in the back more clearly. then i filled it with white lithium grease. just pay attention to the clips and whatnot
oh ya, i did the starter fluid dance. no dice. still though i cant help but think intake gaskets, just a hunch. if i squeeze the throttle i can get'er up to 6500ish rpm. stomp on it....puke. it also threw the #1 plug wire (yes it came off)that was prolly me tho. Oh ya, Tom, waffles are tasty with peanut butter
that thing must be really fast with one pouty man power. ill go ahead and assume you looked at the back of that clutch fork too right? capn double check thats what i am
updates: code 34 still gone. car is stumbling still. ive changed filters iac, maf, no luck. this weekend i think im going to swap everything from the intake on up. i cant hear the fuel pump whining so i dont think thats it. also got a new fender same paint code to replace the smashed one caused partially by a crappy spotter:Flame: i take responsibility only in that i allowed Sam to spot me. lesson learned. help? comments? flamming? anything? this is a thread not a journal folks.
your brat is coming along nicely, you deserve your screen name. now get over to my thread and start posting lol!
well, ya got me there Jezsek, i shoulda said "there is no 1987 MY gen 2 wagon"........in the usa
