Subruise
    5
Everything posted by Subruise
  1. man, that hatch gets AROUND. had the pleasure of seeing it on the xmas tree run.
  2. cut and shut? ive been dismantling a 92 legwag and its surprising how much stuff is similar to my L series stuff.
  3. DO IT. if you can work on stuff. its older, and will need slightly more (usually). then again its only 5 years difference so.......DO IT. .02
  4. i put a carby motor in my 91 loyale. i left the spfi intake hooked up in car and just dropped in the carby longblock. not sure if your dl is carbed but the only shortfall is a slight compression drop (different pistons).
  5. yes, a string. wrap the string around the circumfrence of the belt, mark the string. measure length of said string. done.
  6. i have no sway bar on the front of mt 2" loyale wag. however i installed the rear susp from a gl10 turbo and now it has discs and a rear sb that it didnt have before. other than less understeer and a little body roll I think you should be ok even w/o the front sb. ive been thinking of taking the rear one off anyhow and im sure others run no sb's, just no track days now:-p RV
  7. i used to work at a gas station across the street from a casino. its funny how people come in and buy 8 bucks worth of gas with 50 cent pieces because thats all they have left (blackjack gives em to ya) when, the dayu before theyd be tipping me lol RV
  8. calipers are cheaper @ pnp. also accords are way more frequent than 240s. locally at least. ya ya, used parts i know. rebuild? RV
  9. google it. itll prolly come up w a usmb thread anyway. or at least it usually does. hth RV
  10. shoulda bought the s10 in the background...................then put 20''s on lol
  11. replaced lower ball joints in the lifted loyale, along with (another) cvj. now it doesnt feel like the wheels are coming off:) RV
  12. could be axles or stuck/dragging brakes. check your calipers for slideabilty. they should move easily. hth
  13. ive also heard of a product called evaporust. its an enzyme that eats the stuff. good luck mate
  14. are you planning on changing wheelbase? try searching. loooooots of threads on here. try google too, it usually spits out usmb stuff anyway
  15. thank you for not stopping this project! i cant wait to see more progress. nice ej22 block too
  16. welcome to the board. nice cinematography. good job with the low angle panning. what did you use for a dolly? next time get some action shots, as cool as soobs look sitting still...... they were made to drive! lol. commercial quality, well done RV
  17. welcome aboard, if you (both of ya) need workspace hit me up. my garage loves ea82s. RV
  18. im in parkland. youre welcome here. got stickers for ya too
  19. sounds like you got a hg leak. sorry man. RV:dead:
  20. you get what you pay for man. sorry its sucks so bad back east. seems like id be inspecting a little closer when dropping even as little as 5 bones. RV
  21. look @ your disty, check for shaft play. make sure cap/rotor are good. check and recheck and check timing. google it, milesfox has a great video on timing ea82s hth, RV
  22. well, i remembered to check............11.75'' from the base where the strut fits into the knuckle to the bottom of the cage. hth
