5
Everything posted by Subruise
Ill betcha he EJed that thing, or maybe a 3.6 h6. RV ok maybe not
wow i must have missed something, i used a 1/2" bit on my steelies. i dont remember if i had to hog the hole or not. its snug, but it fits. also, i did the whole job with my craftsman 19.2v 3/8 drive by hand. wouldve been nice to have a drill press. RV
are those honda badges on the upper section of the gate? perhaps this is a rally/moto x support vehicle/ enthusiast? RV
Subaru must have been nuts!!!
Subruise replied to pheonix165's topic in Old Gen.: 80's GL/DL/XT/Loyales...
even if two completely different motors are happy at the same rpms, their respective characteristics in regards to mpg/hp/torque are not really compatible. or at least not as far as i can tell. the discrepancies compound when you start having multiple motors in one platform (ie stock gl vs ej swap) however, your idea on peak torque creating better mpg than peak hp i believe to be accurate. happy vets day, RV -
Subruise replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes the slammed brat was already posted. however I, much like yourself am to lazy to go sifting thru to figure out which post. but ya it got posted. RV -
your panda wagon has a ej25 not a ea82 so the "efficiency band" if you wanna call it that, is going to be different even tho you have the same chassis/body. as far as the turbo tranny getting better mpgs..... i dunno RV -
Maximum Tire Size on 15" Rims + 2" Lift?
Subruise replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
good point VB, im using '91 mitsubishi (i know) montero wheels. the offset is real close to stock offset. RV -
im currently unable to get any pics up w/o a pc at home. you can search my posts/threads. my fenders are cut similar to One Eye's yellow wagon. I will say this tho, I cut my fenders before getting those tires. I origionally had 235/75/r15s and couldnt cut/beat enough to make them fit so all my info is potentially worthless. sorry about that. IMHO if you wanna go bigger and not cut fenders (your car rocks, my car is beat and ugly) i would go taller. others can help out. hth RV -
i have 28" firestone winterforce on my 91 loyale w/2" lift (205/75/r15). i still had to trim tho. RV -
my 86 wagon runs about 1/2 way all day but my 91 loyale wagon runs at about 1/4 all day (except for when the hgs were going on the old motor) RV
1978 4x4 wagon build thread
Subruise replied to noblesablepuma's topic in Historic Subaru Forum: 50's thru 70's
way to go man! i like the oregon/washington liscence plate combo. RV -
horrable rattle coming from engine??
Subruise replied to danzick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
pinging? what kind of gas are you using? -
Also here on the "drift brat". I hear that converting to rwd on the stock 4wd gearbox is bad though. this car is called "rust in the wind" its running nissan rearend (350z i think) and 13b mazda motor -
Are86 GL Wagons squirrly at highway speeds?
Subruise replied to ubtripn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my 86 gl wag does well at highway speeds. check your alignment. my 91 loyale sucks on the freeway because i lifted it and have beat it, it needs new suspension and alignment. there will be a difference between your 86 and 99 no matter what you do but you can install a rear swaybar off a turbo car. hope this helps RV -
EA82 Euro Glass Headlights for H4
Subruise replied to KristjanJohann's topic in Products for your Subaru
i would also enjoy a pair of cornerlights. i plan to paint them orange so they dont have to be perfect. thanx, RV -
i had a hole in one of my covers that let crap in, but not out. as a result i got to learn how to do t-belts. on christmas morning. before a six hour drive. in my climate (pnw) i havent seen significant icing of anything under the hood except for when i didnt have enough antifreeze in my water. (oops) moral: no covers. stuff spins off instead of accumulating. RV
Vent visors on my loyale?
Subruise replied to JDC93loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
rumblee has some vent wisors on his turbo wagon. he said they were on there when he bought the car. hard to think someone ordered em from japan, could be wrong tho. this sounds like a job for: trial and error man! RV however, covering the rear windows will take some engineering, the ones in Robs link/pic were on a touring wag as well (if that matters) -
i used 6X140 wheels off a 91 mitsubishi montero and the offset is perfect. i can tuck all four. the are 15" and dont stick out like a lot of chevy/yota wheels that ive seen. bear in mind not all yota wheels will stick out. RV
sounds like a synchro is going out. most of my soobs have had that problem. 2nd gear here too RV
i know you dont need to hear it, but if its cheaper or at least easier to find why not go ej? you know you can carb those right? my 86 wagon is heading in that direction. SJR's wheeler still has all the ea wiring and a ej w/ no computer= easy (or easier anyway). sorry to you on this, just a suggestion. good luck, hope it works out RV
