5
Everything posted by Subruise
a gc8 is a gen1 impreza. it may be exclusive to the 2 door variety. wikipedia is very helpful. RV
Ideas for the faulty EA82 clock
Subruise replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
solder is always fun. also, swapping the face to one of the "trip computer" faces from the 80s is cool too RV -
fix the clock?? RV -
ok, bone head question here so sorry if its offensive: you guys did plug the coil back in right? ive forgotten to once or twice. usually after a beer i figure it out RV
thanx gary, i was under the impression that i didnt have to use a helicoil if i drilled it out and used a tap. i suppose ill google it, i was just hpoing i could find some some ea82 exhaust stud specific tappage info. RV
so both of my ea82 wags have a stripped exhaust stud on one side. what size tap do i need and what size bit to drill out the hole? PS no, i didnt strip them, one came with the motor i put in my loyale(thanx again, scott). and the other was partially stripped on my 86 but it has a little thread in the end of the hole. thanx folks, RV
so i guess what we've found out is that these thing vary. alot. i just lucked out and have two that are similar. RV
to clear up any confusion my light(s) do come on above the E. and to weather or not it actually has 2.4 gallons i dont know, thats just what the owners manual said. RV
in the owners manual for my 86 wag and my 91 loyale wag it says you have 2.4 gallons left when the light comes on. my light (both of them) come on around 1/8 of a tank (2.4ish gallons). it sounds like either you dont have a light(unlikely but possible) or its malfunctioning. HTH RV
Is this really a '92 Loyale, or is it older?
Subruise replied to Red92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
86. end o story. and for those interested not all loyales had wind deflectors stock. RV -
*pats on back anyway* nice weld man RV
Cost of having a clutch replaced
Subruise replied to ontherun987's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if you dont want or cant afford a shop, i can do it for $200 (you buy parts). i like to pull the motor when i do it. its worth the work to me and i just did it a few weeks ago on my 91 loyale wag. servicing everything is a good idea, taking a motor out is not something you wanna do twice if you dont have to, and workin on that stuff in car isnt fun either. RV -
i have a 2" lift on my 91 loyale wag. 205/75/r15s required cutting in front of rear tires and behind (to move mudflap out of the way). the fenders also got a re-radius. im currently eating axles (they dont break, just boots explode, get clicky etc) and tires in front due in part to bad alignment and part because i didnt drop my xmember(geometry lesson) . i know people say you can get away with it, and you can, but this is the cost. im also pretty sure it can be done better than i did. imho if you dont wanna cut you should go taller to get 15s in there. good luck, *also there are two angled blocks and one straight block for the front facing stud for your lift* RV
Wagonstien taking fully independent suspension to the next level
Subruise replied to Ioku's topic in Members Rides
semi-off topic: so verdict? tie rods flipped good or bad?\ RV -
my GL, let me show it to you
Subruise replied to r81gsr95's topic in Old Gen.: 80's GL/DL/XT/Loyales...
nice wagon man! ive got everything but the passport and michelin stuff for my 86 wag. second owner etc etc. way to go, now just get yourself a fullsize spare under the hood and youll be on your way RV -
EA82 SPFI - Whats that sound?
Subruise replied to Deener's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ya man, sounds like you are pinging. play with the advance a little, try higher octane maybe. glad to hear you got it all together RV -
i dunno if it was one of us..... looks more like a NABISCO move to me RV
can i put spfi on a carbed ea82 block
Subruise replied to mikewilke77's topic in Subaru Retrofitting
my manual says the compression is the same. 9.5 to 1 for spfi and carb ea82. i just put a carb motor in my 91 spfi loyale, and converted it. this motor is better than the other one i had, leading me to believe my book. i had to change the egr pipe on the top of the head (the fasterners were different) and plug the egr ports on the exhaust ports. i left my intake and everything hooked up in the car and put a new longblock in. good luck, RV -
97 OBS rescued from certain death
Subruise replied to bhazard's topic in Meet n' Greet. Your USMB Welcome Center
nic wag! nicer festy!!! man, i miss mine soo much. i had a 91 same color, honda killer. welcome RV -
92 Loyale SPFI wont accelerate
Subruise replied to Jub Nub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
fuel filter. happened to my 91. good luck RV -
WCSS13 "lucky 13 trailrun"
Subruise replied to scoobyclimbs's topic in Meet n' Greet. Your USMB Welcome Center
are cb radios required?? if so ill bring one but its not hooked up:rolleyes: RV
