5
Everything posted by Subruise
Wanted Back Glass for Gen 1 Brat
Subruise replied to sancofw's topic in Historic Subaru Forum: 50's thru 70's
not quite flat either, i have glass. lemme box it and ill email you -
soft vise the impeller then remove pulley bolt and pulley. shaft then comes out. hth
if its not hooked to the plenum it cant meter the air going through it. i think.
this may be ignorant but how do you expect to control the idle without hooking up the Idle Air Control Valve
yup, mine are free
Unusual Temp Fixes To Get You Home
Subruise replied to roadsubiedog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you need 2 batteries and sets of cable....this is how we weld at my house lol...no duty cycle -
its a 14mm w an aluminium crush washer. I use an elongated bolt from an ea82 w ac that I cut the threads off of. works everytime
....tried to turn left after leaving work one day and she went straight (lifted loyale wag in my avatar pic). outer tierod end had stripped under the castle nut. burned myself pretty bad on the y pipe putting a pair of vicegrips (for the hatch, duh) and bungie cording them to the tierod. scary drive home, even though it was perfectly solid -
check the coolant temp sensor. plus if you closed the coolant port to the base of the carb its going to ice up and cease to function
the old ones often deteriorate to a state where they resemble brittle rubber rings. just make sure the new ones are firm, not like a regular oring
http://www.numbchuxconversions.com/Files/EA2EJ.pdf
my hatchy is dry inside, and i live near Nick. I had 3 inches of water in it. I pulled back the carpet and vacuumed the bottom, several times but it worked. Its a lot of work but it can be done
To swap for EJ22, or not to swap.
Subruise replied to Mustakrakesh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
illuminate? lol -
Need help with carb'd EA82!
Subruise replied to Danja44's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ea82s have hydaulic lifters and do not require valve adjustments. make sure youre not a tooth off on the tbelt. if not, time for seafoam -
i ran my breather up under the rear seat bottom thru the grommet. same barb tho
88 GL-10 pushed the rear main!
Subruise replied to MuddyThunder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
back of the intake, below TB. itll have a breather sized hose connected to it -
carb'd ea82 into 89 SPFI wagon?
Subruise replied to wakingtowinter's topic in Old Gen.: 80's GL/DL/XT/Loyales...
youll be fine, ive run both combos -
BOSS 2" EA82 Lift Kits- $100!!!
Subruise replied to The Beast I Drive's topic in Products for your Subaru
Where can I buy another water pump outpipe?
Subruise replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ive got several, come pick one up. i accept beer lol -
getting 4x4 to dis engage
Subruise replied to elgigante's topic in Old Gen.: 80's GL/DL/XT/Loyales...
put it in reverse for a few feet. youve bound up the drivetrain from driving on pavement in 4wd. this is a no no. if that doesnt work jack all 4 wheels up and then try -
"Just EJ it" a different look at this
Subruise replied to tweety's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ejs offer not only more power but better mpg as well. not to mention fuel injection is real nice on steep terrain. -
That car of Jesses gets my vote for most OG subaru ever. how many wheelers have been built, driven, killed, re-built, and finally destroyed all in the span that wagon has been bouncing around? answer: lots.
Oil Leaks, Smoke, UV Dye ...oh my
its the lowest point. Ive had this happen as well. follow the "clean" spots. when you pull that camtower off, youre gonna find a camtower oring thats sucked in and brittle. I dont think Ive ever even heard of an external oil leak from an HG on an EA82. Having not changed the tower seals last time Im almost comfortable betting an HG job on it -
nice come up! cars gonna dominate! dont blow up that single range....im gonna need one for my hatchy (daily). keep an eye on the pnp inventory, theres an 89 gl in tacoma
