ruparts
Everything posted by ruparts
ea82 4x4 camber correction
ruparts replied to Humble Nuto 53's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My 2 cents, Is it possible that someone in the cars past put the wrong struts as in 86 EA82 4x4 type on your car , not knowing better of course, or the springs themselves could be from a different car maybe got switched in the past. Check the part no. on the struts as for early type ea81 application. -
where to buy steering ujoint
ruparts replied to snowstormer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi, I have noticed that the power steering ones and the non/power ones are different from each other. The non power has a taller stem on the rack and therefore the link piece is shorter than the power assisted equipped version. Make sure you chase the right one first time out. LOL -
Hi , I know this must have been discussed before but what all parts and stuff is needed to do this swap? Thanks
Hi, It is a 88 xt6 / awd auto trans. 4speeds . It does not have a 1 position, has: D, 3, 2, . It does not go into 1st gear anytime from any position, but will start off in 2nd gear from any of these , and shift to 3rd , but not 4th in D . If you put it in 2 , it will sort of lock , it is as if the hand brake is set tight, if you give it heavy throttle it will move forward slightly though . As I said the solinoids check to have the proper ohms resistance as do the other sensors in there . Thanks for any help you might have .
Hi , I have a problem transmission that I need help to diagnose, here is the scoop. Has clean fluid and screen, I tested all the sols and sensors inside and they had the proper ohms. I tried a known good computer. Here are the symptoms: Put it in D it starts off in 2nd gear and will shift to 3rd, no 4th gear Put it in 3 it starts off in 2nd gear and will shift to 3rd. Put it in 2 it "locks up" and will move forward slightly with much throttle. Put it in r it will back up fine. Basically no 1st gear and no 4th gear. Any Help on this , THANKS!
Well ,yes the fluid is fresh and no the diff and trans are not on a transfusion program, the speedometer does work , and the filter screen is not restricting fluid flow. I did have one other bit of info, the shifter cable was damaged from a front ujoint failure and it may have jerked the inhibitor switch that is mounted to the shift lever on the trans, (I did reset it )but if the switch was damaged and gave the trans computer bad information can this part cause these symptoms ? I'm hoping that a knowlegable trans guy will see this and help out. Thanks again !
I got this 88 xt6 full time 4x4 with auto trans, it just doesn't shift . here is what I know : Tested all the solinoids inside and they all had the proper OHMS. Tried another (known good ) computer. Road test, in D it starts off in 2nd, will shift to 3rd, and that is all it will do . It will do the same thing with shifter in 3 If you put the shifter in 2, the whole thing sort of locks and will not go at all 1st hold button seems to have no effect It will back up in reverse. If any of you are transmission wise please help me out to diagnose this , its a EAT 4 spd. with full time AWD Thanks !
Hi all, I'm selling this eng 111k(see the marketplace post) .Thanks
It might be the selonoid is stuck open or the wire connector to the skock not making contact , otherwise its like turbone said .
wierd vibration/hummin noise FIXED
ruparts replied to Meeky Moose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi, I have had sounds like that and found the big nut on the axle a bit loose (even after a recent service) sometimes they don't seat in , also the taper washer can develope an edge that causes them to not seat in 100 percent . Moose]well, it almost sounds like a wheel bearing, but has a vibration i can feel in the floorboard and steering wheel.. only does it when the car is rolling, its not dependant on acceleration or deceleration at all.. the faster the car is rolling the louder and faster the vibration is.. the slower the car is rolling, the slower the sound and vibration are.. also when your rolling down the road, if you turn the wheel to the left the vibration and sound stop all together.. when your rollin straight or to the right its there and doesn't change.. i've already changed the drivers side CV axle (was shot anyways) and also the drivers side front hub with a known good bearing.. made no difference at all.. any ideas before it goes to the shop? -
Oil Pressure Issues...Please Help....
ruparts replied to mtsfabman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi, I think you may need to put new seals in the oil pump, it has fixed several clicking engines for me . be sure to inspect the pump for wear marks also. -
Ok For All You Mechanics Out Here....????
ruparts replied to mudrat79's topic in Old Gen.: 80's GL/DL/XT/Loyales...
maybe a shop towel left in the intake or air passage tube and forgot to remove ??? -
'87 Air Suspension R&R Question
ruparts replied to NorthWet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pop out the fender liner gromet, pull the wires through the hole carefully , there is a connector in there about a foot from the strut. -
mayday, the rx still dont run!!
ruparts replied to subyrally's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi, My2 cents worth, I have had a couple of times seen stuck valves which in turn let the rocker drop out of place (ea82) and then NO COMPRESSION-- engine was running and idling fine the night before . Second , the little transistor thingy made onto the coil bracket from about 87 on gave me a time of it , had power to coil and dist but would not fire the plugs -- (did not make and break the power to fire the plugs) from what you have said I think it could be either . (check the compression on ALL )- if good try the coil bracket thing. LOL -
86 XT Electrical Gremlins -- No low beams
ruparts replied to Hondasucks's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi, I've seen several xt's that the switch is not working right . They will switch but not hold the position , there is a ratchet mechinism in there that goes out ,Could be the problem . LOL on it , Post what you find out , all xt info is needed nowdays . -
The Ultimate Lash Adjuster Sollution!!!
ruparts replied to garner's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi, I have found a small restrictor oriface in the cam case that may be the source of all your clicking. The oil to the lifter galley is fed out through the head , back in through the cam case to the lifter galley in the head . If you take the cam case off , pull the cam out , and clean the passage with the restrictor , it has been the cure for me. The debris can collect in a small pocket in the oil passage there and is really diifficult to see even with the thing apart , look close . The cam has to be out of the case to clear this part of the passage!!! LOL and post back if it is your cure . -
'83 Gl Wagon (1800) Transmission Issues
ruparts replied to pixogen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi, I have a 83 FWD trans that was working when it was removed, 50+ shipping , it is in Tx. though. Food for thought, LOL . -
Hi Guys, I need to ask if the intake manifold has vacuum (as on a N/A engine )at lower speed , I know it is pressurized when you are on it, but where is the vacuum for options and stuff . Mainly interested in the selective 4wd on my 86 xt turbo , I see the vac source tube on the manifold to the selonoids and to the selector diaphram, but how can it operate if the manifold is full of pressure instead of a vacuum ? Is there something else to it ? Is there vacuum at lower RPM ?? Thanks for any help
