afewsubarus
About afewsubarus
- Birthday 12/29/1969
Location
Humboldt County
Occupation
Interstellar psychedelic explorer
Vehicles
1990 4WD Loyale
Recent Profile Visitors
afewsubarus's Achievements
Advanced Member (3/11)
0
I recently picked up a used transmission for my 2002 L.L. Bean non VDC. The replacement transmission does not have the shaft axle drives coming from the forward differential. Any advice on how to remove the shafts from the toasted transmission and install them in the replacement. Is this procedure possible without taking apart the transmission case? The replacement came from LKQ and I would like to believe they did not take the time to separate the transmission case just to remove the axle shafts. The part number in question is - Shaft Axle Drive - Subaru (38415AA100)
My 2002 non-VDC Bean Outback transmission part#31000AE640 has a non-repairable forward diff. I can source a 2002 transmission part#31000AE800 from a Legacy GT. My question is will this work? The parts diagram I referenced shows that it does. Although the diagram for #31000AE640 shows that transmission only fitting the non-VDC 3.0 cars, not the GT. Seems confusing. I’m in the Northwest. If anyone knows of the whereabouts of a 2002 #31000AE640 non-VDC or even a broken one with a good forward differential I would be most appreciative. I have quite a few old Subarus and some NOS parts I might consider trading for the transmission.
- 3 replies
- forward differential
- front diff
- (and 2 more)
Thanks, I'll give that a try.
Still no luck unclogging this tank. Does anyone know of the whereabouts of a fuel tank to fit a 1982 Brat?
Thanks, I'll make the effort this weekend.
Is there anything I might damage if I keep trying to force a clog out with wire?
Tried the wire trick, shoved it as far as it would go, no luck.
Thanks, I've tried with my small compressor. Tomorrow I'll remove the tank again and bring take it to the local shop and try their large compressor.
Thanks, I was trying through the outlet tube with the filler cap on, makes more sense to have it off. I'll give this method a try tomorrow.
Any recommendations on how to hook the compressed air up to the filler neck? I tried using compressed air through the line that exits the tank, I only had a small portable compressor from Harbor Freight and it was not successful.
I put a used fuel tank in my 1982 Brat. My old one was rusted inside and would clog the fuel filter within minutes. The replacement tank seemed clean and rust free. I put 3.5 gallons of fuel in the new tank the tank after installation. The Brat fired right up but only because someone was adding liberal amounts of starting fluid directly to the carb. I disconnected the fuel lines at the newly installed fuel filter and they were dry, no fuel in the fuel filter. The nearby fuel pump sounded as though it were functioning properly. I then disconnect the fuel line that ran from the tank to the fuel filter and it was dry as well. Should 3.5 gallons be enough fuel to spill out of the outlet of the tank due to gravity alone? If that metal section of fuel line from the bottom of the tank to the outlet is clogged are there any recommended options for clearing the obstruction? Would any of those options potentially damage the tank in the process?
2006 Outback 3.0. Temp gauge fluctuates intermittently sometimes almost goes to red but then almost as soon as it tops out it drops down. When the car is turned off bubbling can be heard from under the dash. The radiator and thermostat have recently been replaced. I believe I have properly bled the air out of the system. Should I be concerned?
