2
Everything posted by Subi81
My Omega/Leone RX11 Mods so far
Subi81 replied to DJtheGOD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have been thinking about doing the butterfly cutout. How does it seal. What brand do you have? Is it electric or mechanical? How long have you had it on. Sorry for all the q's. -
Sorry I missed you. Hope you got everything back in order.
I live over the hill in Oxnard.
Ya it was fun! Pics I took: http://www.ultimatesubaru.org/photos/showgallery.php?cat=1060
I might be able to lend a hand but have to work up till noon. What JY are you going to?
San Diego "Old School" subaru meet. 8/25/07
Subi81 replied to s'ko's topic in Meet n' Greet. Your USMB Welcome Center
Hey, I might show up depending on how long it takes to learn skydiving and jump out of a perfectly functional airplane. I will give you a call if I go. -
Glad to see it in good hands. Good luck! Edit Sorry this is old news man I have not been keeping up
My 86 t wagon does the same thing. Kinda feels like the clutch grabs then lets go then grabs then lets go etc. all the way up to 3400 rpm. I have an Air/fuel ratio gauge on my car and the surges are timed exactly to the air/fuel ratio. Lean = not so much power, rich=power. After watching this for 3 years this is what I think is going on: Anything below 3400 rpm the ecu will try to achieve a stoiciometric mixture thus the fuel ratio bounces back and forth between rich/lean giving the power/no power situation. After 3400 rpm the system goes into a power mode and just throws a bunch of fuel at the engine, thus smooth power. I have just learned to live with it. A new O2 sensor will respond to a change in the fuel ratio faster and will lessen the surges but not completly eliminate them. Good luck
Think about the forces involved. This is shooting from the hip. If you have vaccum on one side of a diaphram then atmospheric pressure is on the other side multiply this pressure by the area of the diaphram and you have force. Soooooo 14.7psi * Pi r^2 where r is the radius of the diaphram roughly 2" (from memory) and Pi is 3.14 You get 180 lbs. So next time you want to shift you car into 4wd just stand on the lever that is assuming you wieght 180 lbs. Just realized that you are talking about the diff locker I think those diaphrams are smaller so these numbers might not be correct. Lets look at the torque. I am estimating the lever is 3 inches long so max torque produced by vaccum silinoid is f*d=Torque f=180lbs d=3" T=45 ft*lbs Torque in N-m= 61 N-m (so the silinoid theoreticaly produces more torque than you measured) Sorry for the long winded post and I didn't even answer your question, all my manuals are boxed up. sorry
ea82 colors? timing chains!?!
Subi81 replied to SoobGoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
called "Herb" or "Harb" green can't remember which wheels no wheels loaded down -
Yes it is possible. I did it so it can't be that hard. Good bookeeping and a little bit of time will get the job done. Go here for some pics of my install http://www.ultimatesubaru.org/photos/showgallery.php?cat=626 Basically my approach was to create my own harness that addapts an analog dash to work in place of a digital dash. Go here for my post on it: The search function is your friend http://www.ultimatesubaru.org/forum/showthread.php?t=24763 Good luck and feel free to ask any questions.
Crankshaft Timing Belt Sprockets: The Truth
Subi81 replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This might explain my funky idle and a distributor that just won't line up (car runs ok though). Thanks WJM for the research and attention to detail!!! -
Only slightly visible from space. To bad you can't see the look on the helicopter pilots face.
Left my sunroof open and it of course it rained cats and dogs. Did the space heater thing and it worked pretty well. If this is just a persistance occurance and the carpet is dry check your vapor barriers. They are the plastic sheets behind the door covers. Basically they keep any mosture that falls through the window felts from getting into the interier of the car.
Usually I jack at the engine crossmember where the skidplate bolts to.
FLASHER Problem - DRIVING ME CRAZY!!!
Subi81 replied to TheBush's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here are some pics from the MY 1990 manual should be similar: (click to get a bigger pic) -
can't remember where i heard this...
Subi81 replied to Subaru_dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
GD is right I have verified the effect with my AF gauge. Coasting downhill = zero fuel injected. -
removed post. You posted solution while I was posting my response
Wheel hop is bad, Mm-Kay!
Subi81 replied to WoodsWagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You don't have to drop the diff on stock ride hieght loyals. Just take out the lower shock mount bolt. I had to really push down on the drivers side rear wheel (with my leg) to get the axle to slide off the splines but with a friend it is a piece of cake. Beats the heck out of dropping the diff. For some reason the drivers side is always the harder one. Good luck -
my brother lost a wheel at 55 mph. The lower control ball joint takes the brunt of the asphalt and will grind the nut right off. If this is the case I would get it fixed asap!
question about 1986 4wd turbo
Subi81 replied to cls1000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I was having a problem with my ecu connections make sure they are connected. Also check the fusable links in the engine compartment. Electrical problems are fun!!! Good luck -
Just noticed the antlers on top, that pic never gets old
Digi / Analogue Swap - Code 33
Subi81 replied to Sonicfrog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looking back at my notes I have analog #4 (speed pulse out) connected to Digi #13 (speed pulse). The analog dash came out of an 88 RX so I think superdave may have a valid point. You might have to run your own wire? from the speed pulser in the dash to the computer.
