ericcroll
About ericcroll
- Birthday 06/10/1972
Location
Hazleton, PA
Vehicles
1997 Legacy Outback Wagon
ericcroll's Achievements
Advanced Member (3/11)
0
Not sure what you mean by expanded. There is a small amount of play in the main shaft... maybe 1/32" or 1/16"... doesn't seem like too much. The U-joint is practically seized in one direction, so I assumed that was the culprit. I guess I should have mentioned that this car has been operated in FWD mode for the last 80k miles with absolutely no problems.
97 OB Wagon with a 96 Lego tranny... about 200k Miles. I started getting a noise that sounded like a rear wheel bearing, but discovered a bad front U-joint and subsequent output shaft seal/bushing/driveshaft shaft wear. I got a seal, but can't seem to find the bushing anywhere. Is this a dealer only item (it is Saturday, dealers are closed, and I am trying to get this done today)?
The bearing still felt/sounded good when I pulled it into the garage. I'm not sure what circlip you're referring to, which I realize is probably a bad thing to start with, but I'm aware of the snap-ring on the inside (which I replaced), but there seemed to be a fixed lip on the outside that the bearing fit up tight to, so I guess I'm a bit confused at this point. Admittedly, I'm no bearing expert. In fact, this was only the third one I've ever done. The first was on a BMW quite a few years back, and the second was on the back of this car. The first two worked well, with no problems afterward, so I felt confident enough to do this one. I could certainly be an idiot at this point... LOL.
Yeah, I'm starting to think that as well after talking with a few people. I had a five foot bar on the end of a 1/2" breaker bar, and I still couldn't move the thing. I'm guessing that I was able to get about 600-700 ft-lbs on it. I'm about ready to cut it off with a torch, but I don't want to ruin the knuckle, as I just put a brand new bearing in it.
97 Legacy Outback with about 200000. Okay, so I replaced a very bad wheel bearing (due to a loose axle nut) last weekend, and although the bearing now feels and sounds fine, the ball joint is sloppy. I got a new ball joint and started dismantling the thing, but after backing the axle nut off about a turn, it stopped. I can turn it about a 1/4 turn back on, but it gets stuck there now too. It is now loose so that the axle will jiggle/slide in and out of the hub, and also the outer part of the hub is not tight to the inner part (to say that a different way, if the axle nut were to come off, the outer part of the knuckle (lugs and abs sensor ring) would come off with no tools. I've removed axles quite a few times, and never come across anything like it. I am at a loss, and am about to just remove the axle at the tranny and go to the junkyard to buy a whole new knuckle with an axle attached to it. Any ideas?
Well, I changed the pump and the belt with no improvement, and have now discovered a wet spot on the rack. It looks like I'm going to have to change that sucker. UGH! I have heard that there is a thread detailing the process, but haven't been able to find it. I don't suppose one of you has a quick link?
You're saying that you changed the rack for nothing? Hmmm... I'm not so sure that I want to do that. I guess I'll put off the rack change while I keep looking for a leak as my arms and shoulders grow to Hulk-like proportions. lol All kidding aside, it is getting a bit frustrating and as the weather is getting colder, it is more and more of a problem.
Well, I changed the pump and filled with ATF, and the problem remains. Has anybody had a rack failure that they can describe for me, or do any of you have any other ideas? I am still looking for a leak, but I now have such a mess of residual fluid under the hood from my elaborate attempt at draining the old pump using a hose connected to the return line that popped off when I turned the wheel, that I'm having a hard time identifying anything. So far though, I have found nothing obvious.
Well, I changed out the PSF for ATF, and it seemed to get marginally better, but certainly not gone. I am starting to think (as somebody else mentioned) that I have a leak that is drawing air into the system. I'm guessing that since it is sucking instead of blowing, that I won't be able to use the glow in the dark stuff. Somebody else mentioned a bleeding procedure that may or may not work under those circumstances. Is there a way to pressurize the whole system to see where it may be sucking air in?
