revbill
Location
Redmond
Vehicles
92 Loyale
revbill's Achievements
Advanced Member (3/11)
10
92 loyale ea82, hesatation problems ???
revbill replied to ivantruckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Is the CEL on? It sounds like it could be the coolant temp sensor. -
Does the check engine light turn on when the key is in the "on" position? I had some similar troubles and it turned out to be a bad connection under the dash that would cause the car to seemingly randomly stop running. It would sometimes crank and not start when this happened, and I would wiggle the wires under the dash until the CEL came on, then it would start and run fine. (The person who bought it from me was a little more motivated and figured out the problem was a connector that came loose.)
This has happened a few times on my Loyale, and I think it is the ignition switch or one of the wires. Sometimes I get the same no-CEL situation and the car will crank but not start. I can wiggle the wires or pound on the steering column when it happens, and the light goes on, and the car starts fine. I never got around to fixing it, but I would start with the ignition switch and the wiring down there.
Think it might pass emissions?
revbill replied to azsubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My '92 loyale passed with a code 34, but that was in Washington State. I would give it a shot if it's not a huge expense or anything (here you get one free re-test before you have to pay again.) -
It sure sounds like you got the wrong rotor. And I would fix the timing first if I were you, then track down any other issues if there are any. If you can take a picture of the hoses you're talking about and post them in this thread, someone here can identify them for you.
What's wrong with Fram oil filters??
revbill replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Didn't Jiffy Lube or some other chain come up with the 3000 mile interval? I'm sure they would put 500 miles on the sticker if it made people come in for more oil changes. -
From what I understand, it doesn't affect anything. It is there to reduce emissions, but my car passed just fine with the solenoid broken and the CEL on, so who knows. I decided to fix it so that if there was another code being thrown I wouldn't keep ignoring the light. It was easy enough to do once I got ahold of the part.
The code is actually for the solenoid, not the valve. The EGR solenoid is the one with the vacuum line that leads to the valve, and it is the same as the purge control solenoid, but with a different connector. It can also be replaced (with some connector splicing) with solenoids from different cars, but I don't remember which ones (a search should turn up a post about this.) You might want to check the vacuum lines to make sure they aren't clogged before you replace anything, but these solenoids burn out all the time. I had the same thing going on for a really long time, and when I got tired of the CEL being on I replaced it with an extra purge control solenoid I had, and it fixed the problem.
86 GL-10 Turbo FWD questions!
revbill replied to Kitsuneracer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For a car with a mysterious past (why was it donated in the first place?) that sounds like way too high of a price, considering that you're in the most Subaru-rich region in the country. That wouldn't be a bad price for one that you knew was in top-notch condition, but I agree about the potential for problems with the turbo and the suspect cooling system. I'd keep looking for either a less expensive option with known problems you are willing to fix, or something similarly priced that is in better shape. -
cracks on bellhousing?
revbill replied to misledxcracker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think the yellow gasket you are talking about is where the cam tower seals to the head, and it isn't a gasket at all. You use sealant (the kind in a tube) there to seal it up, so that is probably what's leaking. It probably looks crappier than it really is because of all the sealant glopping out. If it is leaking you should re-do it at some point (and probably the valve cover gaskets while you're in there) but if you keep an eye on the oil level it should be OK for your trip. -
There are two timing belts, and the driver's side one turns the distributor so when it breaks the car won't run at all. I would still check the rotor just to be sure, since there is a screw that holds the rotor on that can fall out and cause the same symptoms. If it's working OK you can try starting fluid and/or check for spark at the plugs, and go from there.
Have you checked for spark and all that? You might run through the basic "no start" things in case there's something besides the gasket causing the problem. This isn't to say that your diagnosis is wrong, but I know from experience that having a bunch of crap come down on you at once can cloud your thinking and make you jump to conclusions. The "tries to start" part reminds me of when I spent an afternoon trying to figure out why a Loyale woudln't start before I checked that #@$$#*& screw in the rotor, which had fallen out. And I've started one of these engines with a pretty busted HG and it didn't keep it from starting. If you do need a HG right away, you can get by with what you've laid out. And I wouldn't reuse the oil.
For the Epinions suggested price (who uses that for used car values?) you could get a mid-90's Legacy with a perfectly good transmission, at least here in the NW. For 1500 you should be able to find an early 90's Legacy around here that doesn't need anything. I would pass and just keep your eye out here and on Craigslist. And check the new gen forum for what to check when you test drive a Legacy, since they can have some issues that our old gens don't have.
It looks like the original poster is from Washington (Spokane) and when I had my car tested here they didn't even mention that the CEL was on, so I think he'll be OK. (My car passed with the same problem.) The people who work at the emissions testing stations, at least the one I go to, have a rare mixture of incompetence, apathy, and agressive anger that I've never seen in any other line of work. Thanks for the detailed instructions on getting the code to clear, too. I need to run through those and see if I can get it to go away before I resort to the tape.
For those of you with SOFT brake pedals
revbill replied to EYE_WHY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There's a procedure for checking the brake booster that I don't know off the top of my head, buy you can probalby find it by searching and it should be in any repair manual. It's very simple and only takes a few minutes. I had the soft brake syndrome and it turned out to be a MC in my case. It's always a good idea with brakes to check everything to be sure you're fixing the right thing, and that you're not overlooking another problem. And bleeding the brakes on these cars takes and insanely long time (compared to other cars I've worked on) so it's important to make sure you really got all the air out before you start replacing other stuff. (This wasn't directed at any particular post, just some more input on the brake issue.)
