Mantis_Toboggan
About Mantis_Toboggan
  • Birthday 01/07/1982
  • Location
    Bellevue
  • Interests
    wheelin
  • Occupation
    school
  • Ezboard Name
    I never had one
  • Biography
    shrug
  • Vehicles
    86 GL 4x4
Recent Profile Visitors
Mantis_Toboggan's Achievements
Advanced Member
Advanced Member (3/11)
0
  1. I've been gone for about a year and a half, busy w/ school and all. I know it's short notice, but I'm really eager to hit walker this weekend 8/25 or 8/26. Any of you guys want to come out? I've only been once and don't really know the area. I'm driving a jeep now
  2. Hey, i just saw an old post with a picture of that 'Dual' digital media reciever... i'm kindof a cassette and FM radio guy myself so i've never heard of those before, but holy crap it would be exactly what i need w/ ipod plug in or SD card slot.
    how do you like it? how does it sound? I've got a carpetless brat with cherry bombs so being able to hear iron maiden at full volume is more important than clairity.
    most importantly, do you live somewhere super cold? i've found a lot of cheap car radios like to go to hell when it gets below zero.. does it take it well?
    thanks!
    Graham
  3. What a coincidence! I just stripped my hub out the day before yesterday. How much?
  4. Internet land is funny like that. Nothing beats trimming and fitting!
  5. Dirk said it! Just mount some extra grounds on each cylinder head so the electrons can pull from the frame to the spark plug ground, instead of through the block to wherever the other grounds are (been a while since I've been under the hood of my roo). Path of least resistance vato! Anyways, that's one of the reasons why dex-cool was introduced. You could always flush your engine completely and then run a dex mixture, always a good idea for aluminum engines.
  6. I was going to suggest cracked heads, but you've already found the problem, or a result of the problem at least. Have you checked to see if your elec. fan turns on? My car gurgles every time I drive it. I wonder if I'll ever care enough to put another motor in it.
  7. The problem could be grit in your oil. You might find that your rod/crank bearings are wiped. Could just be age and coincidence.
  8. Why don't you check the FAQ and find out?
  9. So Bill said he'd make you the lift if you came up with the cash? I think I might go for his EA82 4inch if he's already going to be in the process of making yours.
  10. The angle is not in only one dimension. If you make the length of the steering rack one axis, and have another axis to be level with the length of the car, you'll see that it may indeed be shorter because it is pointing, in one axis, towards the firewall.
  11. Hello from Italy!! So you're saying that the thermoswitch is a coiled thermal spring inside a housing that closes the circuit at a certain expansion? This is the point of the light. Which would follow if there is a spring instead of a thermal resistor. I'm actually surprised that an auto manufacturer would use a coiled thermal spring for a temp switch. Even still, you never know what the aftermaket makes. I like that idea, I hadn't considered that. But then again, what about the water pump driven fan? Either way, let's be realistic, take an old EA82 up a mountain in the middle of summer, there's a decent enough chance that it'll overheat during wheeling challenges. Such that I'm gonna want to put that fan on myself, and I don't feel like grabbing a jumper from my wiring box in the middle of the mess. Flipping a switch to an isolated circuit is just right. This is an old car. The previous owner incorrectly wired the stereo, which subsequently was stolen and a lot of the wires were cut when that happened. Any circuit that fails gets a freshly rebuilt one and the important ones have 'just in case' backups. That's just how I am. That being said, I'd like my cooling circuit properly protected from power spikes that may happen. Proper planning prevents piss poor performance. By having properly built, protected circuits with indicators and redundant overrides, I will end up with an quick solution to faulty circuits in critical functions. I'm not trying to say that my way of doing things is the only way to do it, if you want to do it another way, that's fine by me! That being said, if anybody wants to keep their engine from overheating and to have an indicator for their fan, this is the most reliable way to do it. It doesn't cost much, and it'll handle power surges, especially useful if you have winches and lights.
