bstone
About bstone
- Birthday 10/22/1975
Gender
Not Telling
Location
Great Midwest, USA
Vehicles
97 Legacy Outback EJ22 (transplant)
Recent Profile Visitors
bstone's Achievements
Certified Subaru Nut (8/11)
19
Conversion to shocks is called "strut delete" and it does exist for other makes and models. There are several quick struts available on Amazon but with no reviews so I am hesitant to even consider buying them and therefore came here to determine if others have had experience with them. I am happy to have educated you on these two important points of information. Good luck.
It's time for my 97 Legacy OBW AT to get new suspension components. Unloading a strut scares the bejesus out of me so I'm in the market for a high quality quick strut yet I've been unable to find almost anything of this type. I'm also open to converting to shocks but I'm coming up with the same goose egg. Before someone suggests "just get them loaded at your local mechanic" or suggests I DIY it let's just say that isn't an option so don't even suggest it. So does anyone know a source for a quality quick strut or a shock conversion kit?
Yesterday morning on my way to work my wipers stopped working. I made sure to clear off the windshield and remove snow covering the arms prior to turning them on. Once or twice the blades would sweep the window but now nothing happens when I try to turn on the wipers no matter what speed or setting I use. I'm hoping to begin troubleshooting it tomorrow. Here are my thoughts: Check fuses for continuity Inspect wiper motor and try to jump it with 12V to see if that engages the blades Any other ideas? It's frigid outside here in Boston with no access to a garage so I'm hoping to be as efficient as possible.
You’ll need to check the coolant for hydrocarbon gases. Check with your local Advance or AutoZone to see if they have such a tester and report back your results. The 98 EJ25 engine was very prone to HG leaks so it’s highly likely that the missing coolant is from that. As far as a video showing how to replace the HG there are videos but you must understand this is not a beginner type job as you are literally disassembling the top half of the engine and then putting it back together.
First and foremost stop throwing parts and hoping it’ll fix a problem. Is your CEL on? If so pull the codes and report back. Have you done a tune up using quality plugs and wires? I’d start there. Acceleration issues can be so many things including the fuel pump, clogged cat converter, and many things inbetween.
