bstone
Everything posted by bstone
Conversion to shocks is called "strut delete" and it does exist for other makes and models. There are several quick struts available on Amazon but with no reviews so I am hesitant to even consider buying them and therefore came here to determine if others have had experience with them. I am happy to have educated you on these two important points of information. Good luck.
It's time for my 97 Legacy OBW AT to get new suspension components. Unloading a strut scares the bejesus out of me so I'm in the market for a high quality quick strut yet I've been unable to find almost anything of this type. I'm also open to converting to shocks but I'm coming up with the same goose egg. Before someone suggests "just get them loaded at your local mechanic" or suggests I DIY it let's just say that isn't an option so don't even suggest it. So does anyone know a source for a quality quick strut or a shock conversion kit?
Yesterday morning on my way to work my wipers stopped working. I made sure to clear off the windshield and remove snow covering the arms prior to turning them on. Once or twice the blades would sweep the window but now nothing happens when I try to turn on the wipers no matter what speed or setting I use. I'm hoping to begin troubleshooting it tomorrow. Here are my thoughts: Check fuses for continuity Inspect wiper motor and try to jump it with 12V to see if that engages the blades Any other ideas? It's frigid outside here in Boston with no access to a garage so I'm hoping to be as efficient as possible.
You’ll need to check the coolant for hydrocarbon gases. Check with your local Advance or AutoZone to see if they have such a tester and report back your results. The 98 EJ25 engine was very prone to HG leaks so it’s highly likely that the missing coolant is from that. As far as a video showing how to replace the HG there are videos but you must understand this is not a beginner type job as you are literally disassembling the top half of the engine and then putting it back together.
First and foremost stop throwing parts and hoping it’ll fix a problem. Is your CEL on? If so pull the codes and report back. Have you done a tune up using quality plugs and wires? I’d start there. Acceleration issues can be so many things including the fuel pump, clogged cat converter, and many things inbetween.
Last time I bought a used OEM starter which worked for several months but then the click-no-crank happened so I put in the new contacts and plunger but the problem of click-no-crank persisted. I then replaced it with another used OEM starter (the current one) which was fine for a few months and then the problem of click-no-crank occurred. I thought the current starter was new from Advance but I was wrong as it's definitely used OEM. Sorry for that confusion! I'm open to replacing the contacts and plunger again since it's cheap and easy but I'm curious if you think that will help the current click-no-crank or if I should go with a Denso starter. Also, to ensure I have the crank relay set up correctly so I take a voltmeter and probe the wire going from the relay to the starter spade connector and the other probe from the relay to the battery? Or can I just probe the 30A fuse? What is a correct voltage reading (I'm assuming 12V or abouts but want to make sure). Does it matter if the key is on or does the engine have to be actively cranking?
OK I just wired up the relay and so far it’s working. Why didn’t anyone tell me it was pretty easy to do? The relay didn’t have any diagram so I found one which was previously linked but the numbers weren’t exactly the same so I swapped around until the solenoid would engage. I made sure to use a 30A inline fuse connected to the 30 spade. The real test will come tomorrow after it’s sat overnight in the cold. That’s when I have the most difficulty in starting.
