bstone
Everything posted by bstone
Misfire problem
bstone replied to dgot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Did these all come up at the same time? If so then you almost certainly have an electrical problem. It is possible that they are all due to the knock sensor, however. -
A few weeks ago I noticed the rear defroster light no longer comes on when the switch is pressed. It also appears that the defroster isn't working. I checked the fuse under the steering column and it lights up on both poles. I am open to suggestions of what to check next. 97 OBW AT with an ej22 transplanted into it No codes
It's HIGHLY likely that the tranny shop doesn't have the right machinery to pull Subaru transmission codes. I was getting an AT Oil Temp light flashing 16 times on startup, so I brought it to the local independent tranny shop. They weren't able to pull any codes from it, but I did the "handshake method" and got a code for the Duty C Solenoid. You can build your own scanner and use a laptop along with the OBD-II connector and pull the code. Google for FreeSSM and you can have your own top-notch Subaru code scanner.
