bstone
Everything posted by bstone
Glad you made it. Before you spend money on a new trans drain the fluid and refill three times. Also add in a thi for Lucas stop slip. It might buy you some life. IL is less greedy than it used to be. I'm from there and moved out to mass 7 years ago. Every frakkig road has tolls here both getting on and off.
P0519 Code ????
bstone replied to KIX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Let us know how it goes. Also, bring me some cookies. -
P0519 Code ????
Lots of good info here: http://www.subaruforester.org/vbulletin/f88/check-engine-light-code-7297/#post85844 Tell your mechanic to get a new code reader. -
100k is around when the head gaskets tend to go. You need to replace it with an OE Subaru t-stat. Anything else simply doesn't work and tends to overheat the engine. If you compare the aftermarket and OE t-stats you'll notice a huge different. When did you check the coolant? Sincerely doubt it was replaced. Find a mechanic who specialized in Asian cars and know Subaru well. Have them check the coolant for exhaust gases using the chemical test. If I had to put money on it I would bet your head gaskets are going. Sorry. :/
An external head gasket leak? I didn't know the 95s did this. I strongly suggest a second and third opinion from other shops. If it is an external leak then you can go to your local dealer and get a bottle of Subaru Coolant Conditioner and add it to the coolant when the car is cold. The price quote is very high for a head gaskt job. For that price you could get a fully rebuilt engine installed. I suggest the ej22.
