bstone
Everything posted by bstone
2000 Legacy miss
bstone replied to jwox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Swap the injector. See if the misfire follows the injector. -
I think I have a leak coming from the intake manifold or the manifold gasket, so I got another from a local boneyard that also includes an EGR, throttle body and 2 fuel injectors for $75. Not a bad deal! I have gotten everything removed and the intake is loose, but there is a singular bolt that holds on a metal line going from the EGR back to the engine and it just won't budge! I first used a 17mm open wrench but it just succeeded in rounding it. So I banged on a 16mm and it's doing the same. Here's a picture of it: I am about to push it to a shop a few blocks away that is known as a great Subaru shop, but want to see if you all have any ideas first. I've already soaked it in liquid wrench but it just ain't budging. Ideas?
Replaced all 4 last summer (379 days ago) with Moog products. It breaks 2 days ago, but there is a "Limited Lifetime Warranty". I go off to Advance Auto Parts (where I got it from), take the tire off, take remains of link off and return it. It comes 2 hours later. Meanwhile, I have them test my alternator as the battery is getting a low charge and sometimes failing to start. Alternator tests bad, battery tests good. Fast forward 2 hours later the link comes. Turns out the price is now $5 less, so they refund my credit card those $5. INCREDIBLE! Go out into the lot and put on the new link. Then I headed off to local Subaru dealer to get the alternator. (Heard too many horror stories about aftermarket and rebuilt ones.) Call them before to ensure part is in stock. "Yes" they say. I get there and guess what- computer says they have it but it's not in stock. They call another dealer. Same story! The third dealer 8 miles away actually has his eyeball on it. I go there, pull the old one, and they have a large box entitled "Remanufactured Subaru Alternator" sitting on the desk. I am not thrilled with it being a reman, but at least it's Subaru. 12k/12month warranty. Now the car charges like a champ! Then I go off to Firestone for the second alignment in 2 days. They failed to tighten down the strut bolts, where it connects to the steering knuckle, when they did an alignment yesterday. I tightened them down and they redid the alignment pronto. I have lifetime alignments- not a bad deal. Not bad for 3 hours work!
Ball joint help
bstone replied to kd7dej's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I spent 8 hours last night trying to get the lower ball joint off my driver's side steering knuckle. The head of the bolt sheared off while trying to remove it followed by 8 hours of blow torching, drilling, drill failure, drill only turning counter-clockwise, drill bits breaking off, etc etc -
inner tie rods
bstone replied to yesyeah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Just remember, you'll need an alignment after you do the tie rods. I am doing both sides (driver and passenger) and replacing both the inner and outter tie rods. I was smart and got the lifetime alignment by Firestone last year, so I don't have to pay for it again. -
Ball joint help
What brand of ball joint? I've read some nasty complaints about cheap aftermarket ones. I am doing mine soon and going with Moog.
