Everything posted by bstone
No Reverse
bstone replied to General chaos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI laughed out loud a few times by how you write! Sorry about the trans, but you're frekin hilarious!
Project: Rebuilding AC compressor
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know. I want to do this for the experience. My AC works great, but I have this extra compressor and I want to tinker.
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGotchya. Should I get one of those kits to rebuilt a compressor? I figure I may as well replace the clutch and whatever gaskets and such that I find along the way. Do you know where I can find such a kit?
I have a known bad AC compressor from my 97 OBW AT. The symptoms are thus: the clutch does not engage and when I tried to add refrigerant oil to the ports and turned the clutch by hand the oil did not get sucked in. The two Master ASEs who I was working next to both said "the compressor needs to be replaced". I did that (it was expensive!). Now it's time for a project, even if it's only to be done once and isn't worth my time. I want to experience, damnit! So, people, talk to me about rebuilding an AC compressor? I googled it a bit and found a few folks who did this and took a lot of pictures. I guess I need to know about any sort of "AC rebuild kit". Where would I get such a thing? Any advice, thoughts, feedback, etc. Thanks.
a cyinder 1 misfire after plug and coil-on-plug change
bstone replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRain dance will probably work. I echo what GD says. He's the expert.
Can I drive with the AC compressor removed?
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGrowl. The new (used, from boneyard) compressor is bad. Clutch sputters and barely turns. Growl. I am returning it in the morning, but they only give store credit. Any ideas what I should get for $125?
Should I use a Walker catalytic convertor?
bstone replied to mwatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat'd be illegal, me thinks.
bstone replied to mwatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI put a Walker in last summer. Works great and was really affordable.
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe guy at the yard says I need to add oil. How much, where and what type?
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am on my way to a boneyard to pick up a used but good compressor. How do I install it? I hear about having to put oil in it, but what sort of oil and where? Leaving in a few minutes and back in an hour or so. Thanks, folks!
Is it possible to override disabled cruise with CEL on?
bstone replied to us3r123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI echo this. Your gas mileage is going to *seriously* suffer. If you are going on a road trip you certainly want to have the exhaust system in fine working order. Go to a dealer and get an OE sensor then find someone to replace it for you for a lot less than the dealer.
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWasn't that hard but one of the bolts was hard to get to and I had to remove a metal fuel line out of the way. Once I did that then it wasn't too hard. I should have used a swivel socket but didn't remember I had one. Oops.
bstone replied to us3r123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do not think it's possible. The ECU isn't that interactive. Sorry.
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's a really good idea. I'll do that in the morning. I haven't driven anywhere, only fired up the engine to make sure the squeaking noise had gone away.
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe belt for the compressor only turns the compressor. Power steering and the alternator is the other belt. I removed the AC belt.
I removed my AC compressor this afternoon due to the fact that it's making a high pitch squeak noise and it no longer blows cold air. I am waiting for the local dealer to get one in stock. In the meantime, can I drive with the AC hoses disconnected? They are not obstructing anything. Removing the compressor wasn't the easiest. I had to remove one of the metal fuel lines going into an injector in order to gain access to the compressor bracket mount. Thanks.
Replacing pulleys, balancer, idler- need advice and part #s
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI might go with a new one. I know it's a lot more expensive, at the same time I caution all the car owners I work on "if it moves don't buy it used". Also, this is *my* car, not someone else's, and I would prefer to have a nice new part and not something used. This is sort of the reason why I just paid several hundred $$$ for OE pulleys and tensioners instead of getting an aftermarket kit.
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUpdate: All pulleys and the balancer is/are installed. Replaced the timing belt, as well. Additionally, did the oil pump and gasket since I happened to have it. Next is to replace the AC compressor as the current one doesn't work and has a high pitch noise coming from it.
Shift lock help
bstone replied to FLYRYGUY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had that problem once when the neutral position sensor was bad.
Replaced HG, now have knock/tap on left head + overheating
bstone replied to gdubya's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo 2 oil changes, each about 50 miles apart. Throw in some of that Magic Mystery Oil. The second time. Let us know how it goes.
Duty C Solenoid.... stuck
bstone replied to goms187's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou mean you took off all the bolts from the transmission extension housing? Make sure you got them all- some are really up there and a pain to get out. Get a drain pan underneath as you're going to lose several quarts of trans fluid when it comes off. Take a thin screw driver and just start slowly prying. Be gentle but use gentle force. Also get some Red Permatex and new gaskets for the housing and solenoid. This is a good opportunity to reseal the transmission.
Valve Cover Gasket - oem or aftermarket?
bstone replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry an online subaru dealer. You can probably find the OE for $15 less than the local dealer.
Front end Clunking sound going over Bumps 2005 OB
bstone replied to studogger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you mean the strut mounts?
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's exactly the point. This is arguably the most important maintenance that you can do on the car (lumping in the timing belt and water pump). I would much rather go with a superseded OE part that has 2 bearings than an aftermarket with one. I am going to be spending a few bucks on this, so may as well do it right. I am in MA and subarupartsforyou is CT, so I figure it'll be here in a day or so. No rush, tho the whining balancer is getting me nervous. I also ordered an OE timing belt and will do that when all the pulleys are replaced. Does anyone know if I missed any important parts?
bstone replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's an experience is the local parts dept vs an online OE dealer (who has a store not too far from me, so I can save on the shipping) Part Local (CitySide Subaru) subarupartsforyou.com 13085AA080 Idler Pulley w/teeth (1) 81.82 62.00 13073AA142 Idler Pulley-smooth (1) 74.95 56.00 13068AA051 Hydraulic Tensioner Adjuster 149.95 99.00 PULLEY CRANKSHAFT, BOLT & KEYWAY FOR 1997-2009 LEGACY OUTBACK 2.5 179 145.00 Total: 485.72 362.00 I think it's pretty obvious who I will be buying from. $123.72 difference in price for the same exact parts. Holy Moses!!!
