bstone
Everything posted by bstone
Well, the CEL came back tonight. Was driving from New Haven, CT to New York City and the code was for the primary O2 sensor. It was dry and normal driving conditions. No rain and not wet. My options, as I see them: 1) Remove the o2 sensor and Ohm it out to determine if it's working correctly. Does anyone know the right the ohm range for the primary O2 sensor? 2) Replace the sensor with a new one. There is a Subaru dealer about 20 minutes from here. I am tempted to do this as I am pretty certain the sensor in the primary cat is damaged. It sat in my backpack for about a year and I throw that thing everywhere. I've checked the wring harness and it looks intact. Ideas? Thoughts?
Drove from Boston, MA to New Haven, CT today. While on I-90W I noticed white smoke coming out from the back of my car. All the gauges were good and the car was driving fine, so I pulled over and looked. I was leaking a lot of transmission fluid (red, clear fluid coming from the trans). After about 100 miles it seemed to stop. I checked the trans fluid level and it appeared high. I did add about 2qt last week as I had a few bolts loose on the trans oil pan and had leaked some out. I think I seriously overestimated how much came out at the time when the bolts were loose and overfilled the trans. Is it possible that the extra fluid caused an increase in pressure which caused the trans fluid to come out? But when the volume returned to normal that stopped? It's shifting fine. I'll check for leaks again.
p0400 code
bstone replied to vwbuge1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The solenoid can die and the vacuum will be good. -
p0400 code
EGR. Stuffed up EGR or faild EGR valve might cause stumbling and low power. -
You need to start a paper trail in order to win any future dispute. Send the owner a letter in the US Mail via certified mail. In it you need to summarize the entire issue and offer him an opportunity to fix it. Say you expect to hear from him within 10 days. If he doesn't reply then dispute the charges. If he sues you then you have a paper trail to show the judge (or credit card company) that you've tried to resolve the issue.
Agree with GD. Find a good Japanese/foreign car shop that is well experienced. Have them to do the head gaskets, reseal the engine (cam, crank, oil pan gaskets), water pump, timing belt, idle tensioner and pulleys. Your engine will go for another 200k before any issues if the job is done right. Make sure they use ONLY the upgraded Subaru head gaskets. No aftermarket parts.
