bstone
Everything posted by bstone
Today's saga: Got the following O2 sensor from Advance Auto Parts for $98.99: http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product__18470480-P_291_R|GRPEMISAMS____?cm_mmc=ET-_-Trans-_-Confirmation-_-General They are having a sale where if you buy $100 or more online and put in the code you get a $50 gift card. I also bought some engine degreaser so now I have a $50 card coming to me! I also bought a 7/8" O2 sensor tool, went into the parking lot, jacked up my car (used jack stands, also) and went to town. That darn thing wouldn't budge. It was really, really rusted on and in no good shape. I ended up yanking the old O2 sensor's wires off and it still wouldn't move. I ended up rounding it and gave up. I returned the tool and went to a garage down the street. The guy there charged me $25 to swap the O2 sensor. He had to use a blow torch to get the old one out. Considering the tool cost $18 I think spending $25 to have a garage do it was just fine. I reset the code and will fill the tank in the morning (I'm at empty) and I hope and pray this goes away for good.
Update: CEL is back, complaining of bank 1 sensor 1. Turns out you need to ignore "bank" and instead focus on sensor. The rear sensor, in the second cat, is broken. Snapped in half. The front sensor is fine as it's new and OE. So, what should I replace the rear sensor with? I understand it does not need to be OE, but I do not want to be splicing. Suggestions?
Yeah, big thanks to SubaruFred for the exhaust leak. His suggestion and the $50 I spent to get it fixed probably has saved me hundreds of dollars in gas. Here's the other issue- the gas meter is off. I have a 16 gallon tank, but when it's down to E and I fill the tank I only get about 11 gallons in, which means there is 5 gallons still in there. Should it read E at 5 gallons? Any way to recalibrate the gas meter?
So I went to the independent muffler shop across the road and they found a leak coming from one of the flanged on the passenger's side right before the converter. They cut out the flange and put on a metal pipe and welded it on, for $50. The hiss is gone and the car actually seems more responsive now.
ABS on
bstone replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
DIAL UP?! Where are you? -
ABS on
http://www.ultimatesubaru.org/forum/showthread.php?t=117608&highlight=read+abs+codes
