bstone
Everything posted by bstone
CEL came on while driving this afternoon. Scanned and it came up as P0136 Oxygen O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2). I have a new OE O2 sensor that I can swap but it appears this is a CIRCUIT issue, not a cat below efficiency or a O2 sensor failure, per se. So, folks, talk to me about what to do. Is this the first or second cat? Should I check the wires going from that cat up to the wiring harness? Should I pull out the O2 sensor and clean it off? Your ideas are welcome.
Update: I replaced the coil with an OE one I had sitting in the basement (got it from a junkyard a few months ago). Started her up and all was beautiful. No more stumbling, no more low lower, no more misfire. Just for good measure I drove to the Subaru dealership 5 miles away, still with no misfire or stumbling. I figured I may as well buy the wires and I had a 15% off discount coupon, which got me the wires for $57, including tax. Replaced the wires and filled the boot tubes with dielectric grease in the parking lot and she now drives like a dream. Thanks everyone for your help. I was hoping not to have to replace the plugs and with your help I didn't have to. It also seems that I preformed a tune up! Shalom!
I am headed to the dealer now to get OE wires. They have them $64 and I printed up a 15% off coupon from their website. I have an OE coil in the basement that I will put on before heading out, just in case that solves the issue and I can save the coin. If neither the new coil or wires fix the problem then I'll replace the plugs, but that's a PITA as we all know. I can do it in about an hour if all goes perfectly.
Update: Went to Advance Auto Parts today and got WD-40 and dielectric grease. Took the boots off, sprayed them out with WD-40, let them dry and then filled them with the dielectric grease. Also took off the wires from the coil pack and sprayed them down. It didn't help. I am still misfiring, but it's not turning on the CEL. I am going to get new wires tomorrow from the local dealer (I have a 15% off coupon) and will also put on an OE coil pack that I have in my basement. If that doesn't solve it then I'll have to replace the plugs, but that may have to wait until a really sun and relatively warm day.
I am using NGK Laser Platinum plugs (same as OE plugs), NGK wires (same as OE) and a coil I got at the parts store (tho I have an OE coil that I can put on). I did replace the knock sensor over the summer as I was getting a code for it. It was nice and tight when I got it in. You think there might be some moisture getting into the electrical connector? Like I said, once I cleared the codes after the engine was on for a few minutes the problem didn't come back and power was restored.
