bstone
Everything posted by bstone
Head gasket
bstone replied to ncwillus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Pressure leak down test and HC test are good indicators of HG failure. -
Replaced the Inhibitor Switch (aka Neutral Safety Switch), including the cable. Took about 2 hours as the exhaust pipe was majorly in the way. Put everything back together, cleared the codes and turned it back on. Still doing the idle rise and fall, over and over. Now I am also hearing a grinding type noise, coming from the switch area. I don't think it's the inhibitor switch. Maybe it's the TPS or it could be the IACV that I replaced it with. Ideas?
I am still looking for the TPS adjusting method in the service manual. I have the many, many PDF version and search isn't so easy. The code coming now is only P1507, even after the replacement IACV, so I am thinking this is the issue and not the IACV. So, I ordered this from the AutoZone that is just around the corner and they said it will be here Wednesday after 3pm. The junkyard is refusing to sell my just one component from the transmission.
Update: Cleared the code and put in new TPS. Drove around and CEL came back saying P1507 (IAC Valve). The IACV & Solenoid in there has been replaced, so I am thinking it might be this Inhibitor Switch. Once or twice the AT Oil Temp light flashed 16 times, but it doesn't any longer. So, where do I get the Inhibitor Switch from?
Went and swapped the TPS with the old one and then back to the new one. No longer getting the P1700, but back to the old TPS code. The idle is going from 1.5k to 2.25k over and over. I sprayed carb cleaner down the entire engine to try to find a vacuum leak, but could not. I am at a loss right now. Can I possibly have gotten a bad TPS? What are the odds? Or, am I looking in the wrong place? Should I be looking at soemthing else, like EGR? I have another EGR valve off the junk car.
