bstone
Everything posted by bstone
Check the plugs, wires, coil. Make sure they are all snug. Unplug and replug all the airhoses, paying special attention to the air ducting and the small hose below the MAFS. Also, unplug the MAFS and try without it plugged in. You'll get a check engine light but it will eliminate a computer glitch. Lastly, unplug the negative battery terminal and let the computer reset for 5 min before trying again.
I checked again tonight, doing another pressure leak down test. I got one of the mechanics to listen with his ears for the hissing. It turned out to be the upper radiator hose. I replaced it and then repressurized (after refilling the tank) and the pressure remained constant. I think I found my culprit.
Went to the local Subaru dealer and got a bottle of the Coolant Conditioner for $1.75. Then went to the grocery story and got a bottle of ground black pepper for the same price, exactly. Added both. Let car run for 15 min with heat on highest. Will check coolant level in the morning and do another leak pressure test.
Did another pressure leak down test. This time I removed the hose to the external tank and the pressure went in. Pumped it up to 16PSI in the yellow zone. Took about 10 minutes, but I heard a clear hissing and the pressure was going down very quickly. The hissing is coming the engine compartment- I would bet the headgasket. Yup....
I would be willing to pay the money for a CCR rebuilt engine, but it is expensive. Is there anything different in those engines other than a general rebuild? The JDM engines have between 55-65k miles on them, approaching the HG failure point. I can easily swap the HGs before putting the engine in the car. Do you all think that would give me an engine to last a long long time?
The answer to that is I have been restoring this old car and plan to drive it for years to come. I recently put in a low-mileage trans, replaced the entire brake system (rotors, calipers, pads), replaced all 4 sway bar links, replaced the oil, trans, spark plug and valve cover gaskets, rear main seal and oil separator plate (while the trans was out). Just trying to determine the best course of action. I am fine doing any of them. Also, why not FelPro's HGs? I've heard they are superior to even the "new" Subaru HGs.
