bstone
Everything posted by bstone
Got in the car earlier and tried to shift from park to reverse and nothing happened when I stepped on the gas. Couldn't shift into drive or any lower gear, either. I got out got began to feel around the neutral switch and was able to put the Range Select Lever into reverse which worked. I palpated the boot leading from the switch which houses the cable and I definitely feel that the cable is disconnected in the middle of the boot. Does anyone know if the cable is meant to disconnect or if this sounds like a snap? I'm in an extremely rural area so getting parts takes a few days. Would anyone be able to recommend a part number? There's an Advance Auto Parts about 20 miles from me.
A bunch of news stations did reports showing that those machines are likely to cause more problems than they solve as they tend to force the fluid through the trans at far higher pressures than the trans is designed for. Numerous manufacturers have issues technical bulletins indicating that these machines are not meant to ever be used with their transmissions and using them can seriously damage a transmission, voiding the warranty, and costing the customer thousands of dollars. Trans flush at 3:44.
My turn signals have suddenly stopped working. They don't flash either on the console or on on the car itself. They worked one night and the next morning they just didn't. I have checked all the fuses under the steering column and they all light up on both metal contacts. All of the fuses under the hood do as well (at least those that have metal contacts). Any leads or places to start would be useful. I will report back here with my progress. Thanks, folks.
