bstone
Everything posted by bstone
Sounds like a non-OE thermostat was used or there is air in the system which needs to be burped out. The EJ25 is a difficult engine to burp so you may want to read around for some hints. I generally squeeze the upper and lower radiator hoses in attempt to displace air trapped in the lower parts of the system, adding coolant as I go along.
97 OBW AT with a transplanted 2.2 New problem. The left turn signal does not work when the headlights are on but does work when the headlights are off. The left arrow is slightly lit up (a light green) when the headlights are on. The right arrow works just fine. Really at a loss to explain this one. SOS. Thanks.
If the CEL comes back on then you might end up getting really lousy gas mileage. O2 sensors sense the amount of oxygen after combustion and the computer adjusts the fuel-air mixture accordingly. If the O2 sensors are bad and a CEL is set then the car goes into default mode, which means super bad MPG. Worth it to fix it.
Update: Insurance company is sending a check for $2300, which includes the collision deductible (300) and purchasing the car back (200). I picked up the Suby and got AAA to tow me to F&S Yard this afternoon. While there I got two headlights for $75 each, a hood for $100, and radiator with fans for $150. The owner, Bob, stayed with me until 9pm as I helped him use chains and clamps to pull the various malformations on the radiator support back into shape. He even did a bit of welding to get broken bolts out of their threads and made sure everything was tightened down. He charged $180 for this and it was worth every penny. All in all the car is now working, drivable, and fine. I paid $425 for parts and $180 for labor. Not bad, eh?
