About Speedbuggy
- Birthday 10/26/1975
Location
Enon Valley, Pa
Occupation
project manager
Vehicles
Subaru based Manxter
Speedbuggy's Achievements
Advanced Member (3/11)
0
I'm going to pick up one of those Bosch valves and see how it works. Ill report back when I'm done. Thanks for all the help BTW would anyone have a rough idea how much that valve might increase my idle while fully open?
That looks perfect for my application. Now I just have to find one
Your first solution sounds promising. How is it plumbed in? Your second suggestion is what i already have. That block is made for a stepper motor, and I haven't been able to find a PWM that will work with it nor a version of it made for a PWM.
Any links for a throttle kicker? Sounds like an intriguing idea.
Yes it's custom. I believe the original Idle Control valve plugs into the throttle body right? I'm not even sure what the throttle body I have is from, but a Subaru tuner told me it's not a stock Subaru body.
I'm more worried about having to tap the intercooler and intake manifold.
The ECU will take care of that. Once it sees the manifold pressure change it will increase the fuel to compensate. I've been trying to figure out a way to do a time or temperature based solution but haven't been able to come up with anything yet
Thanks.. I've read all up on that.. The megasquirt WILL support an idle control valve, but my ECU wont.. Well, it WILL support a PWM valve, but I haven't been able to find a way to get a PWM valve into the intake path. I have a block for using a stepper valve, but my ECU won't control a stepper valve.
ON my buggy (http://www.ultimatesubaru.org/forum/showthread.php?t=113679 ) that's running a turbo charge EJ25D, controlled by an EMS Stinger ECU, I don't currently have any sort of idle control, which means when the engine is cold it tends to stall when you let off the gas until it warms up a bit. I want to add an ICV, but my ECU won't support one. what I want to do is get something like this: http://www.ebay.com/itm/1-4-SS-12V-DC-Solenoid-Valve-STAINLESS-VITON-S20V-/290722239826?pt=LH_DefaultDomain_0&hash=item43b0655552#ht_2389wt_1163 And plumb a line from the outlet of my intercooler, through the solenoid and into my intake manifold upstream of the throttle body. Then all I'd need to do is flip a switch and the idle should jump up.... Theoretically. This valve has an 1/8" inch orifice, so I'm not sure how much that's going to boost my idle. I'd like it to idle at around 1200 rpm when the switch is engaged. So, first, is there any merit to this idea at all? Second, does anyone have any idea how much of an idle increase I'd get with basically an 1/8th" leak in my intake manifold?
Thread resurrection! I'm still trying to fine tune my cooling setup and get the heater working properly. In a normal Subaru, if there' always coolant flowing through the heater core, how is the temperature of the air coming out of the heater ducts regulated (ie. what does turning the temperature control knob do)?
Hardy-har-har Unscrew, ubolt, yada, yada, yada... I just want to make sure that taking them off isn't a major undertaking. I've never worked on a DOHC engine before (all my real engine experience is on a Classic Volkswagen Beetle engine where the valve covers are just held on by bailing wire and you pull them off as part of normal maintenance).
